AH FabricationsSky Insurance
    boost-addict's Avatar
    Aug 2011
    977
    multible missfire and fuel trim bank 1 system too lean golf 1.6
    sorry didnt know were else to stick this
    basicly a friend has got a golf 1.6 auto mk4.
    it had a bad missfire so he got the leads and plugs changed and ws told cyl 4 plug was dry and cyl 1 was very sooty and dirty
    this has resovled some what the lumpy idle and misfire on reving, but he still gets the same problem.
    so i cleared he codes and hes not sure if this made the idle and revs better.
    it idles ok, and then goes lumpy, but does rev freely now in a fashion, but the knock sensors are still sensing a missfire in cylder 1 and 4
    hes yet to travel home today to find if the problem has been cleared
    misfire on cly 1 and 4 and some time 3, and also fuel trim bank 1 system too lean
    what can be at fault here? injectors, fuel pump? does this sound like a fuel delivery problem? how can i check if it is this
    other then that i suggested compression but not entirely sure
    unfortantly i only have the freeshare version till i gather the cash up for the real deal
    VCDS-Lite Version: Release 1.2
    Monday, 30 September 2013, 09:36:07.
    Control Module Part Number: 06A 906 033 BL
    Component and/or Version: SIMOS33 1.6l 2V 00AT4578
    Software Coding: 00033
    Work Shop Code: WSC 01271
    VCID: 6AA741AB0567
    Additional Info: WVWZZZ1JZ3W147765 VWZ7Z0B5430645
    6 Faults Found:
    16687 - Cylinder 3: Misfire Detected
    P0303 - 35-10 - - - Intermittent
    16555 - Shareware Version. To Decode all DTCs
    P0171 - 35-00 - Please Register/Activate
    16685 - Cylinder 1: Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 35-10 - Please Register/Activate - Intermittent
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 35-10 - Please Register/Activate - Intermittent
    Monday, 30 September 2013, 09:38:36.
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55 ,56,57,75,76
    Address 01: Engine Labels: 06A-906-033-APF.LBL
    Controller: 06A 906 033 BL
    Component: SIMOS33 1.6l 2V 00AT4578
    Coding: 00033
    Shop #: WSC 01271
    VCID: 6AA741AB0567
    No fault code found.
    Readiness: 1110 1101
    Address 02: Auto Trans Labels: 01M-927-733.LBL
    Controller: 01M 927 733 LK
    Component: AG4 Getriebe 01M 4985
    Coding: 00000
    Shop #: WSC 00000
    VCID: 847B8F138703
    Address 03: ABS Brakes Labels: None
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0011266
    Shop #: WSC 01271
    VCID: 341B9FD31723
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Jan 2011
    northants
    165
    check compressions
    Aug 2011
    977
    all were fine
  1. Fuel Trim; Bank 1: System Too Rich
    By johnone in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2014, 01:02
  2. 17536 - Fuel Trim Bank 1 (Mult): System too Lean
    By cagiti in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2011, 19:49
  3. 17545 - Fuel Trim: Bank 1: System too Rich
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2011, 16:32
  4. Fuel System Too Lean - Bank 1 and Cylinder 3 misfire.
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 12:14
  5. Fuel Trim Bank 1: System Too Lean Fault
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th August 2009, 15:46
