Monster MotorsportVolks Autos
Results 1 to 8 of 8
    ScottishS3's Avatar
    May 2011
    Moray
    1,489
    Valve Caps Stuck!
    Hi All!
    Well I bought some S line metal Valve cap covers that are locked via an alan key. Problem is, they are stuck on and I can't get them off. The alan key won't even fit into the hole now! Anybody have any ideas how to get them off?
    2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, RS4 Grille, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, S line Suspension, Dynamic Boot Spoiler, K&N Typhoon Induction Kit
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by ScottishS3 View Post
    Hi All!
    You could try a bigger size maybe an imperial key or a Torx bit sometimes they can get enough grip when refitting you caps add a thin film of grease to the threads so you can wade through the Elgin floods without your cap's seizing to the stems
    good luck
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Mole grips on the rubber valve and 10mm spanner on the valve cap? Failing that you'll need to cut the cap off and have the valve replaced.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    as above they always get stuck on
    unless you copper grease the 1st
    i have to have all valves replaced on out ST cos of that
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I had this exact issue with a set some friends purchased for me.
    At first I couldn't undo them- it turned out the Allen key they provided with the kit was absolutely crap and after I had done them up it must have shat itself at the thought of undoing them :-\
    I used my own set in the end and managed to undo them.
    Needless to say I didn't tighten them back up as chances are the Allen key is made of the same material as the screw is - so will only be a matter of time until they got fully jammed in the valve cap.
    If the top of the screw was rounded off - then the next thing I was going to do was to try and undo it by using long nose pliers - as there was a good mm or 2 to play with on mine.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Audi Dynamik's Avatar
    Sep 2011
    2,126
    Thats bad news ! Beware everybody, the little screw will rust to your valve so you cannot get your dust caps off so avoid alan key dust caps at all cost.
    When i had my Bmw i got some dust caps with the alan key lock and they started rusting onto the valve so i had to take them off.
    When i picked up my Dynamik i got a free set of Audi valve caps though and i noticed last week that the Audi logo fell out of one of the dust caps then a few days later i found the Audi logo on my drive so i super glued it back on.
    The problem is the metal dust caps seem to corrode somehow onto the valve and they are a bugger to get off so i take them off and give them a spray with abit of WD-40 every now and then so they are lubricated and do not rust on.
    In all furnace plastic dust caps are far better but just do not look half as good imho.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Apr 2013
    Aberdeenshire
    595
    Use something like copper grease as different metals attack each other causing corrosion.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    if you still cant get it off, take it to a tire place, let them cut the valve and replace it with a plastic cap.
    my vw ones rusted up and wouldnt come for for love nor money
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
  1. Oil Around The Filler Cap - PCV Valve / Filter
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th August 2010, 01:47
  2. Valve caps stealers...
    By phille87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 00:47
  3. Audi valve caps
    By stoke_audi in forum Parts Requests
    Last Post: 26th May 2009, 15:48
  4. Tyre valve caps stuck on??
    By stewarta13wsb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2008, 19:58
  5. Metal dust caps stuck on...any ideas?????
    By mickc in forum Detailing
    Last Post: 5th October 2005, 09:30
