Volks AutosAH Fabrications
    Jan 2013
    31
    The bolt is stuck and i dont know how to remove it
    hi if you can watch my video showing you were the bolt is stuck
    My Audi TT The Bolt Is Stuck - YouTube
    After changing the rear spring on my audi tt and then accidentally opened the wrong bolt which resulted in this drama! Now not sure what to do now
    Any advice on how to remove it please
    or is there anyone around romford essex
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Thats a bad one. Not a lot you can do really apart from try to align it all back up (as the bolt is at a horrible angle) Do not try to force the bolt - i.e hammer it in....once its all aligned slowly screw the bolt back in. You will get mechanical damage within the hole but its not gonna make much difference. You may have to get assistance to align it all back up possibly with someone trying to move the entire nearside rear set up whilst the car is on stands/blocks.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    You could have a look to see if there are any other bolts/fixings you could remove to ease the alignment or maybe taking the load off the rear suspension or even putting the load on (reverse onto some ramps). I'm not sure which bolt it is exactly but from the pictures I can only assume it is some sort of control arm.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Yikes, I was in this position not too long ago on my S3 upgrading to adjustable camber bars, is the bolt itself stuck, or can you unscrew it slowly to extract it? If you can get the bolt out, what you need to do is use a screwdriver to adjust/move the rose joint on the hub carrier straight. Once you've done that, try and see if everything lines up without putting the bolt through. Once you are happy, now this is the tricky part, you need push against the brake disc face for it to line up and put the bolt right through before rosejoint moves to the position like in the pic.
  1. Anyone know how to remove the glove box lid/door
    By chris_marshall in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2011, 18:57
  2. Anyone know how to remove the number plate fitment?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2011, 21:19
  3. Anyone know how to remove the vent rings?
    By audiv6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2010, 18:54
  4. Anybody know how to remove the airvents on the A3?
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2008, 20:10
  5. In case you guys and gals dont know...
    By S3K in forum General Chat
    Last Post: 19th November 2003, 19:51
