Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By @udi A3
Thread: Take it on the chin or garages fault - stripped thread on hub
    Jan 2007
    I asked my local garage to rotate my tyres in doing so they managed to strip the thread on one wheel nut holes on the hub. I asked them how it happened and they said the nuts can get rusty could this cause this or is it most likely the garage screwed up ? The guy said he should be able to rethread but to be honest I would prefer hub replaced.
    Thxs
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,002,022
    Follow Administrators On Twitter
    Could be.. but also if you put the bolt in an air gun and start the bolt going into the hole that way rather than starting the bolt by hand first... bad things can happen
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    I would expect the garage to return the car to how it was before they started work on it, i.e replace/repair what they have damaged.
    Ask admin to advertise here
    Administrator
    Oxfordshire
    1,000,002,022
    The problem is how do you prove it.. Now the thread is damaged and you weren't there to see it happen. They might if they are playing nice offer to fit the part for free and you cover the cost of the part. Always a tough position unless someone want to fall on their sword.
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    663
    The garage are responsible for there actions,as said bolts need hand starting first before ratchet.
    But if you weren't there how can you prove it even though it was ok before you took it........
    May 2012
    RETFORD, NOTTS
    1,753
    Next time dont be lazy, the sun is out, go out and wash and wax it and rotate them yourself :D
    Administrators likes this.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Mar 2009
    38
    Had a similar issue not long ago, garage whacked the air gun on and broke the locking wheel nut and then said the bolts had seized in and it was not a fault of theirs - claimed they had the breaker bar on it not the gun. Also said 'we can try to hammer a socked on it but it may damage the alloy so dont want to do that' wasnt until later I spotted they had tried exactly that and you could see the chips in the alloys. Normally a good place but must have had a newbie on it that day!
    Took the car to my mechanics with new locking nut, used the breaker bar and eye presto, no issues. He said straight away, they have used the gun on this to cause this damage.
    Wasn't pointless trying to stand and argue the toss, nut was £10 from the dealers and they had all their excuses lined up.
  1. HELP Bad day at the garage fault code list as long as my arm. 2.0t fsi
    By slim boi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th February 2012, 17:22
  2. So the S4 saga continues!! Fault codes
    By dsmclark40v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2010, 21:35
  3. Audi take DRLs to the next level on the new A8
    By Staz in forum General Automotive Chat
    Last Post: 6th December 2009, 18:37
  4. Friend came over to help take pictures of the car.
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2009, 17:24
  5. Taking advantage of the good weather..
    By ollyhawkeye in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th April 2009, 20:57
