EM TuningMonster Motorsport
Results 1 to 9 of 9
    boothy1994's Avatar
    Apr 2013
    Somerset
    22
    need help with brakes
    ive recently bought a w reg audi a3 sport 1.8l and ive had to put a few things right to get it through the MOT and one of them was a binding brake, i have fixed this but i had to take the caliper to pieces and fix it. however now the brake is not binding but the braking system is not working, the pedal is travelling way too far and their way too weak, also if it helps the brake pedal is making a sqelching noise :/ not sure what it is, ive tried bleeding the brakes a couple times but the front bleed nipples are corodded so ive been bleeding the front ones from the pipe where it attaches to the caliper. can anyone give me some pointers?
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    still air in the system.why havent you replaced the nips? I think you better let someone who knows what they are doing have a go....
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Can't really bleed brakes properly without using the caliper nipples, get them sorted asap! No brakes = dangerous!!
    You've got to have a laugh!
    boothy1994's Avatar
    Apr 2013
    Somerset
    22
    i cant replace the nipples without braking them, dont mind getting new nipples but cant get these off
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,076
    Soak the nipples in PlusGas / GT85 then heat the surrounding bit of calliper with a blowtorch - this may free them.
    If the nipples snap you may be able to use an easy-out to wind out the rest of the nipple.
    Failing that - you may need to source a set of replacement callipers.
    boothy1994's Avatar
    Apr 2013
    Somerset
    22
    alright cheers, ive heard that if they snap then an easy-out should work, ill have a go later and let you know how it goes.
    boothy1994's Avatar
    Apr 2013
    Somerset
    22
    well they didnt budge but im fitting a new master cylinder tomorrow hopefully fingers crossed that should work!
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    I'm sure a new master cylinder will fix the seized bleed nipples!
    A4 Avant 1.9 TDi Sport GmbH
    Mar 2007
    salford gtr manchester
    557
    Quote Originally Posted by boothy1994 View Post
    hi mate when you go to buy the master cylinder change your mind and buy 2 new front brake calipers no disrespect mate but you really need a garage to sort them or at least someone that knows what they are doing . you don't need me to tell you how important the brakes are please don't take chances with them
  1. Need help with latest interior mod!
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 11:59
  2. Need help on brake pads
    By mazzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2004, 10:10
  3. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
