Chris NottSky Insurance
Results 1 to 29 of 29
Like Tree1Likes
  • 1 Post By dbm
Thread: Headlight Washer/Levelling System Check on MOT - Its Official
    27,033
    Well obvious from title, but the new regs have come into force from yesterday, mine failed purely because of a hose had come loose & I had temporary disabled the system via coding.
    But, he says if the headlights are hid's, then they have to test for them, he did, failed me because it was disabled, I re-enabled, fixed pipe then & there, passed.
    So you've now been warned, its on the test & any mot station that doesn't check with cars with hid's, will now be breaking the law.
    olethalb's Avatar
    Aug 2012
    314
    i need a new pump, mine's seized
    thanks for heads up
    ctd
    Oct 2012
    Plymouth
    105
    will get all those who have retro fitted HIDs without the leveling system and washers, watch this space
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Iirc not all cars that came with xenon/hids had the self levelling lights at the beginning. How will they test these?
    May 2009
    south yorkshire
    628
    I guess your mot tester didnt quite tell you all the rule. If you have xenon lights that have washer jets and self levelling then they must work.if your can has xenoon lights they only illegal if they have an incorrect beam pattern if not fitted with washers and auto levelling . For anyone with aftermarket hid kits if your lghts produce more than 2000 lumens of light then it is a failure unless fitted with auto levelling.
    But if the plod pull you over they cannot fine you /whatever if you state that you're lights only produce 1990 lumens .as they have no way of testing this .only an mot station has the equipment neccesary .
    May 2012
    RETFORD, NOTTS
    1,749
    Hollow, im pretty sure that was the old rules, if its fitted it has to work, if no level/washer fitted its not tested.
    We will see though, my MOT is up for renewal now too
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Re: Headlight Washer/Levelling System Check on MOT - Its Official
    Quote Originally Posted by @udi A3 View Post
    Be interested to see what they say.
    I'm going to have chat to my local garage and see what they say.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by ScottB5 View Post
    Me too. My garage - which is also my MOT testing station - actually supplied and fitted the after-market HIDs I had on my B6 about four years ago. I haven't seen any kits on their shelves for a good while now, so next time I'm in there (service and MOT due end of April) I'll ask them what their understanding is of the legislation as it stands.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    May 2012
    RETFORD, NOTTS
    1,749
    I do have manual adjusters from halogen lights still, so should be ok. If not ill be selling some oem xenons soon
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    I just spoke to my servicing and MOT garage about retro-fit HIDs, and their understanding of the current legislation. As far as they are concerned, retro-fit HIDs are an MOT failure, so they they no longer stock, sell or fit them.
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Read here looks like you have to have washers and self level lights for MOT.
    Dec 2012
    Hampshire
    137
    Quote Originally Posted by wesmaster View Post
    I'm not quite sure how you work that out from your link. It clearly says 'Headlamp levelling and cleaning devices when fitted for HID or LED headlamps'. 'When fitted' is the pertinent part. It doesn't say anything about them having to be fitted.
    Dolphin Grey B6 A4 Avant 1.9tdi
    Mods so far: Allard EGR delete pipe, Shark remap, Bilstein B12 Sportline suspension
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by olethalb View Post
    thanks for heads up
    x2 never bothered replacing the pump as the washers just make a mess of the front end and waste loads of screenwash (I buy the fancy nice smelling stuff from VW).
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    I'm pretty sure some older cars that came with factory hids didn't have auto levelling or wash... My old omega for one... *bit of fuel. For the fire right there... *
    Currently rolling in a SKODA!!!
    Mar 2011
    141
    Quote Originally Posted by hollow View Post
    Good point & thanks for the info.
    Most of the people (even some working on the MOT inspection) don´t know that lights under 2000 Lumens don´t requiere auto levelling.
    Mar 2011
    141
    Quote Originally Posted by Arrkon View Post
    Even the new ones.
    the New Audi A1 & VW Beetle are some examples.
    They have HID headlights (under 2000 Lumens) with no washer or auto levelling
    Jan 2013
    Moray
    228
    Quote Originally Posted by Malfuss View Post
    Finally, someone writing the truth rather than knee jerking.
    My old Evo 9 have HID headlights as standard. No washers or auto leveling. It still sales through the MOT as they were never fitted to the car as standard. The main reason this rule has come in is to prevent the use of the aftermarket HID kits being installed and dazzling other road users. I myself do a lot of road cycling and my biggest bug bare is being blinded by incorrect headlight adjustments or HID's.
    Here's one to look up and ask yourself - why must only HID lights have headlight washers? Why not every type of headlight? Answers on a postcard
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Jun 2011
    Wellingborough
    1,157
    Quote Originally Posted by Steve220 View Post
    I get dazzled by normal halogens, either the bulb is not seated correctly in the lamp or the headlamp is broke. its soo annoying, and them new Merc Xenons are sooo bright, they should be illegal.!
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Arrkon's Avatar
    Oct 2010
    1,641
    As I understand it, Generally because HID (as the name suggrsts) and Led headlamps are far brighter/intense than your usual 55w dip beam halogen, and as such any dirt on the lens can refract the light far more easily than halo's.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    I don't understand why they did away with head wipers.
    They was so much better than just jets.
    I also thought they was really cool watching the little wiper wipe.
    dbm
    dbm's Avatar
    Preston, Lancs
    511
    Because Xenon lights are so powerful they would melt the rubber!
    A mate of mine works for Leyland Trucks and is up on all the rules & regulations.
    RS3 | TTS | A3 3.2Q | S3(8L)
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Quote Originally Posted by dbm View Post
    Really?
    WOW.
    Did not think of that.
    Apr 2013
    Barry S Wales
    60
    Heres the mot inspection manual which is issued by VOSA themselfs. Every mot should be done to these standards. This will clear up any problems about hid self leveling/washers
    Enjoy
    http://www.motinfo.gov.uk/htdocs/m4i00000101.htm
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    I was thinking about this.
    If the rubber melts, why don't the plastic with in the headlight melt?
    Apr 2013
    Barry S Wales
    60
    I dont think the rubber would melt as hid bulbs are lower watt than halogen bulbs so produce less heat
    Jul 2013
    West Mids
    65
    I believe the latest generation of Xenons as fitted to Mercs and some of the other top marques use 55w Ballasts and burners and are very very bright.
  28. #27
    Oct 2012
    426
    the place where i go just passed one of cars with the wash system disabled, stupid rule if you ask me nice to see common sense being applied, what next your car failed sir because you haven't waxed it recently.
  29. #28
    dbm
    dbm's Avatar
    Preston, Lancs
    511
    Well, that MOT centre is breaking the rules and would lose their license if it was found out. If the system is fitted, is must be operational.
    These rules are for safety - HID lights are very bright and dazzle on-coming drivers very easily. A cleaner lens helps keep that in check.
    Viking likes this.
  30. #29
    Greeny233's Avatar
    Mar 2011
    Llangollen
    656
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Quote Originally Posted by cooper86 View Post
    Enjoy
    m4i00000101
    Well according to that it just says check operation of any wash or levelling system. So if it ain't fitted it doesn't have to be tested. If its fitted it has to work. That would be my understanding.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  1. Headlight washer system, how does it work/wiring info please
    By @udi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2013, 23:58
  2. GROUP BUY - Clips to fix your headlight self levelling system (A3/S3 8L)
    By Sparkesandnoise in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2012, 12:09
  3. Need a clip to fix your headlight self levelling system ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2012, 13:20
  4. B5 8D2 Headlight Washer System Project.
    By Topplumb1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2012, 14:59
