Badger5AH Fabrications
    a05boothrj's Avatar
    Oct 2009
    Leeds
    A3 2.0 TDI starting problems
    Hi,
    I have a 2005 A3 Quattro 2.0TDI (140bhp)
    Recently I've found the car is having problems starting. It starts eventually after turning over for about 5 times as long as normal although when it does start it's quite noisy until I rev it through. It's done this about three times now and after the first time I had it in a garage and had the plugs changed on their advice although this doesn't seem to have worked.
    When the car is on tick over (I.e. at lights) the revs range from 800 to 1000. When at 1000 there is a slight vibration throughout the car. Also when I accelerate vigorously there is a little smoke out of the exhaust, not terrible but certainly not the norm.
    The car has done 120k miles and I had the timing belt and dual mass done at 80k.
    I went through a stage of having a problem with the turbo hose coming loose but after a few attempts at getting it sorted it doesn't seem t be an issue now, not sure if this is relevant.
    I am female so please don't get too technical but I know the basics so any advice would be greatly appreciated.
    Thanks in advance.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    This would be better off in the 8P section, but maybe a mod will see it and move it
    Is this hot starting thats a problem or cold starting ? If hot, could be the starter motor, when the cars hot, ecu doesnt fuel for starts, and starter cant turn the engine over fast enough to start it. From cold, its not a problem, as ecu injects fuel. Mine does this.
    A rough idle / vibration is often a sign of the dual mass failing. Though wont hurt to rule out any other running problem.
    Smoke from a diesel is the norm, with in reason. Is it all the time ? Or do you only boot it now and then ? Its common for cars that are driven gently, to soot up the exhaust, then when you finally do boot it, all the recent soot is blown out. Give it some good hard blasts, and see if it still smokes after the initial few blasts.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
  1. GOLF/A3 2.0 TDI Starting Problem can anyone help?
    By slick-A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2012, 20:07
  2. A4 (1997) 110bhp TDi starting problem
    By benh999 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th July 2009, 13:18
  3. Tdi Starting problems
    By s1hal in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2008, 20:27
  4. 2.5 TDI Starting Problem
    By PeteS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th July 2007, 11:20
  5. A3 2.0 TDI Starting problems
    By imported_simey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2005, 20:18
