Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    LED Fog Bulbs???
    From what I've been reading, most LED's don't seem to have the light output to work as proper fogs! they're just for show. I want some that will light the kerbs on a foggy lane.
    now I've seen some new 20W 4 chip Cree's on e-bay, does anyone have any experience with them?
    H11 Xenon WHITE 20W CREE LED Car Fog Bulbs VW BMW AUDI | eBay
    thanks.
    2009 A3 SB 2.0T DSG S line
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,320
    Speak to trups (User t8ups) he will advise you. ) x
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    In fog the last thing you want is a white light as the light will just scatter back at you, yellow is the best colour for fog.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    Modern fog light housings are designed to project a flat beam, and seeing how they're low to the road on every car except some Mercedes ..scattered light shouldn't be an issue.
    Sandra I'll pm t8ups for his advice immediately. Thanks.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    I've now binned the idea of LED fogs and today received my ultra white halogens from t8ups ...just need to get outside to fit them now.
    Dec 2012
    Hordnean, Hampshire
    157
    Feel free to post up some pics of them in action once fitted
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    LED Fog Bulbs???
    will do when I get dry time to fit them.
    Oct 2012
    492
    I've ordered a set aswel mate also ice white dip and main bulbs aswell let us know what they are like and also how hard they are to change
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,822
    Fitted the bulbs tonight, T8ups' s on the left, Ring Xenonmax on the right! The Ring bulb is brighter, but it's slightly yellow! I've yet to align them. ...opinions? Is t8ups' too blue?? they're bluer than my LED's & make my nice white Xenons seem yellow.
    Here' a quick how to with pics for changing fog bulbs:
    1. Remove the surround, just grip the inboard part of the blades as indicated below & give it a sharp tug toward you! The tab (circled) on the left side should be last part out & first part in when refitting.
    2. Remove 2x screws (circled), rotate empty bracket from behind housing at white arrow below
    3. Press clip into plug and wiggle free of bulb! unit is now free!
    4. rotate bulb housing 45o anti-clockwise and carefully withdraw from lens housing.
    refitting is the reverse! once the surrounds are properly aligned, they need a short sharp bang with the palm of your hand to get them to click back into place correctly. Remember the tab on the left (Pic 2) goes in first.
    It took around 20 minutes in all, and I had to feel for a couple of the screws as it was dark outside.
    Dec 2012
    Hordnean, Hampshire
    157
    Looking good.
    It is tricky getting everything to match colourwise, but it's pretty close. If you were being picky you could argue they were too blue, but not necessarily enough to stop it looking OEM
    Oct 2012
    492
    They look great mate and a good right up on how to install thanks
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,198
    Quote Originally Posted by Artimus View Post
    cheers buddy was looking for this guide for a while
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  1. LED Fog Light Bulb Resistors Fitting Guide
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2013, 10:57
  2. Error Free LED Fog light Bulbs
    By Paul @ Unit9Rempas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th June 2012, 15:37
  3. led fog light bulbs
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2012, 17:06
  4. H4 LED Fog light bulbs
    By Rigla in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2011, 02:19
  5. Fog light bulb - quick question
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th August 2004, 02:41
