EM TuningMonster Motorsport
Results 1 to 9 of 9
    S.line's Avatar
    Dec 2011
    251
    Engine temperature.
    Hi guys and gals, I've got a bit of a dilemma here. I've got a 2.0tdi 143. My car isn't warming to 90. It's getting to the mark half way then going up a bit when I'm going up hills, then down when going down hills. I thought thermostat so took it in to Audi a few weeks ago for warranty repair who diagnosed the stat was shagged and replaced it last Friday (warranty runs out on 17december :O). Today it's doing the same thing!
    Please help :'(
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    827
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Have you had it scanned for fault codes yet? Could be as simple as the temperature sensor.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    S.line's Avatar
    Dec 2011
    251
    Engine temperature.
    Just had it in today and basically it's "its normal for this engine temperature to fluctuate when outside temperature drops below 5deg C. This is due to the engine being so efficient. This can change due to driving style, cabin heater settings and load.&"
    Does your car temp fluctuate?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    827
    Quote Originally Posted by S.line View Post
    No not normal at all, temperature should warm up after about 15-30mins max. and hold steady at 90'C. Even my 2001 Mk4 Golf did this.
    My car temperature does not fluctuate, it warms up and holds at 90'C as should yours.
    S.line's Avatar
    Dec 2011
    251
    Engine temperature.
    It doesn't. I'm at Audi now about to take the car. Just spoke to one of there drivers and he's never seen it!! He drives stacks of Audi's all day!!!!
    Lets see what they say.
    S.line's Avatar
    Dec 2011
    251
    Engine temperature.
    No joy. It's a phenomenon that's normal....apparently.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    827
    Definitely not normal across the VAG range. Get it scanned and see what flags up?
    Nov 2012
    194
    Engine temperature.
    Mine was never on 90* only when accelerating a lot, but it dropped to 70-80* quickly.
    Changed the thermostat yesterday, and its now 4-6 mins to reach 90* and stays there...
    The old stat was in closed position, but maybe it is the inside of it(wax?) which looses its ability to open at its specific degree(87*)??
    But mine's fine now...
    Easy job.. 30mins or so + 2-2 1/2 liters of coolant
    S.line's Avatar
    Dec 2011
    251
    Engine temperature.
  1. Engine temperature
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2011, 10:13
  2. Engine temperature reduces LOADS with air con...
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2010, 21:35
  3. Engine Temperature Warning every morning
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2009, 21:38
  4. help - engine temperature problems!
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th November 2008, 01:09
  5. Engine temperature at 50! 1.8T cab
    By zeratul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2008, 22:53
