EM TuningMonster Motorsport
Results 1 to 7 of 7
    May 2012
    RETFORD, NOTTS
    1,753
    MOT suprises on cars online history check.
    I bought an A6 V6 auto a few months back with an ABS warning, amongst other faults.
    MOT is due next month so had a look to see what had been replaced or advised last yeah to get an idea.
    Now heres a copy of last 2 failures.
    Garage one failed:
    Date of test:06/10/2011Certificate issue refused (Fail)
    Odometer reading:145,173 Miles
    Reason(s) for refusal to issue Certificate
    Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
    Rear registration plate deteriorated (6.3.1d)
    Offside Front Front position lamp(s) not working (1.1.A.3b)
    Nearside Front Headlamp not working on dipped beam (1.7.5a)
    Nearside Front Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    Offside Front Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    Offside Front Upper Suspension arm has excessive play in a ball joint (2.4.G.2)
    Offside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
    Exhaust has a major leak of exhaust gases (7.1.2)
    Fuel filter Fuel system component leaking (7.2.3) **DANGEROUS**
    Advisory Notice issued
    Nearside Front Direction indicators slightly discoloured (1.4.A.2f)
    Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
    Front Brake lining(s) wearing thin (3.5.1g)
    Oil leak
    Garage 2 failed:
    Date of test:18/11/2011Certificate issue refused (Fail)
    Odometer reading:145,495 Miles
    No Advisory Notice issued
    However garage 2 did work to the car (there stamp on the number plate previously failed on)
    and garage 2 then passed:
    Date of test:18/11/2011Certificate issued (Pass)
    My concerns:
    If garage 2 did the work needed for the MOT (at least the number plate change), why did it then fail on just a headlamp not working, as this was indicated in the previous failure and none of the other faults were on garage 2 failure.
    When i collected the car, there was the abs fault (new abs ecu fitted to fix the no comms error while in my care), there was a failable exhaust blow, the headlights are still deteriorated, the low tyre was replace by myself the day i collected the car. And the oil leak was there.
    None of these faults were included on the pass tickets advisery, so would assume they were fixed (one the fail advisery but not the pass i would assume faults are fixed?)
    IMO the mot has been done by a dodgy garage, and the car parked up for 6 months before selling on. (within 1-3 months of mot it can be challenged) so waiting 6 months would cover the mot stations mistakes.
    This is just my opinion, and garage names have been removed of course.
    I suspect when i mot it next month ill be left with a very similar failure sheet where the exhuast oil leak and lights are concerned.
    whats your thoughts?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Apr 2012
    N. Wales, LL22
    1,224
    how many miles on it when you got it?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Sadly a lot of things are open to interpretation as too what constitutes too much play, or a dangerous oil leak or even a poor output from a headlight.
    May 2012
    RETFORD, NOTTS
    1,753
    148883miles today, not sure about milage when we got it. we have maybe covered 1500-2000 miles since we have had it.
    I apreciate there is a lot of 'mot tester discretion' .
    Im confused as to why the owner may have had garage 2 replace the number plate, but not fix the headlight for instance before the mot test?
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    In my opinion he probably decided to take it to a "friendly" MOT tester after the visit to the first garage.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    May 2011
    Portsmouth
    397
    It could be the first MOT station wanted to work on the car and in their opinion the car needed working on.The best thing I recommend is to get friendly with a mechanic, never bribe them with beers or anything, but whenever your car needs working on take a tin of biscuits or something to eat / drink while they are at work. Build a rapport and then you'll always have a friendly garage for honest advice. My mechanic is worth his weight in gold for the work he does for me. Charges me £10 to do the tracking :-D
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    as ads says
    the 1st garage could have been trying to charge for work that didnt need doing
    id put it in for a mot see what comes up.
  1. Dane iv found your cars little brother, check out the plate
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2011, 12:05
  2. VOSA MOT HISTORY CHECK
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2011, 23:50
  3. MOT'd the car :o(
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2009, 20:34
  4. Potential Buyer, Want to check car's history
    By Lemeshianos in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th February 2008, 15:57
  5. MOT on new cars
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2004, 23:34
