JMB RetrofitsSky Insurance
    Oct 2012
    expensive multitronic repair whose fault
    I took my 3litre cabrio, with a slight judder in multitronic at slow speed, into dealer. They said they had forgotten to change oil at 40k so changed it (now at 70k) cured for a few days but now worse so they say needs new clutch pads at £1500! Could this be caused/exacerbated by them forgetting to change oil, as car has been driven very gently from new?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    They forgot to change it @40k miles? Surely, the responsibilty is on you to keep tabs on that, but they maybe should have reminded you @40k'ish miles?
    Anyways, I think you should ask for some goodwill on the repair, telling them you paid X amount for a car that you chose over a merc/bmw of similar model for it's build quality and reliability, but apparently not.... and that you're disappointed that something has failed at only 70k miles!
    Failing that, get a quote from your local independant specialist for the same repair.
    Oct 2012
    Thanks. Apparently it is part of the service schedule. I don't check if an item has been left out by a main dealer. Do you think it could have affected the gearbox
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Quote Originally Posted by robertthirkell View Post
    I did some research whilst looking for a B6/7 A4, and I believe it's a common problem when the auto gearbox service is not carried out. Not really read up on what damage it could cause, but looks like this could be it!
  1. Stereo volume fault - Repair or replace?
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 14:38
  2. 500 repair to engine fault
    By zeratul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2009, 12:03
  3. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
  4. Internet fault
    By Wolfsburger in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 2nd June 2003, 01:32
  5. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
