ETKA Access Please
G
_G_
Can anyone provide a diagram for the breathing pipe that goes from the tank to the throttle body?
I have a persistant code for EVAP P0441 - Incorrect Flow
I replaced the N80 but it has returned.
I am yet to test with VCDS again.
Thank you
Audi A3, 8p2, 2.0 TFSI (2007)
http://
thank you... now which part would it be?
a red circle or number would help a great deal. cheers jtp
Number 3 are the fuel pipes and return, no 12 is the breather pipe.No 7 is the fuel filter that can have a pressure regulator depending on model.Unfortunately as my etka is unsubscribed, i dont have the vin facility
im going to look into this more closely.. ive ended up buying etka off evilbay.
i cant figure out which one would be the tank breathing pipe.
apparently there is a pipe that goes from the throttle body to the fuel tank or something... its all evap related
frikkin evap codes are a nightmare!
I completely understand.Its a parts manual not a service manual ! Good luck interogating it though.Might be worth a visit to the stealers though, on the pretext of buying the pipes...but want to know if they are the right ones.If your etka is duff, pm me and ill send you a copy of mine that works and updates
G
11
3K
_G_
G
959
916
