Chris NottSky Insurance
    Jul 2012
    Headlights not working
    Hi, My 2007 Audi A5 headlamps are not working.
    They are D3S HIDs.
    Head up display on dash is stating "Right dipped headlight / main beam headlight" and then "Left dipped headlight / main beam headlight".
    Neither sidelights, main beam or high beam are working. All other lights are. However, if i leave the indicator on (left or right) and switch engine on, the side light will illuminate (parking light).
    I have checked fuses in left and right door way and boot. I have changed both bulbs (like for like).
    I had it in at an independent Audi garage yesterday and they are stumped too!
    Dont know what to do next. Am i missing a relay or reset button?
    Help please. Martin
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    have you had a fault code scan yet ?
    thats what id do 1st
    Jul 2012
    Thanks for reply. Yes, I had it in at an independent Audi garage and they checked/cleared faults.
    Since then/above post, switch has also been replaced to no effect.
    Also, yesterday the drivers side light started working.
    I switched ballasts around and it may be them that are at fault.
    Currently have both ballasts off vehicle to air dry naturally. As I think with all the rain recently, moisture may have got in.
    Please let me know if there is anything else I can do?
  1. Dipped headlights not working
    By JonnyO in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th October 2011, 09:49
  2. S3 Headlights not working
    By bennn in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2010, 10:01
  3. Dipped headlight not working
    By m40rcd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th October 2008, 11:23
  4. Headlight not working
    By DIPS_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2006, 19:35
  5. headlight levellers not working, any thoughts
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2006, 05:32
