Chris NottJMB Retrofits
Results 1 to 13 of 13
Thread: Tyres
    StateOfPlay's Avatar
    2,230
    Tyres
    Not liking the look of my front tyres, depth gauge shows the centre as 3 mil but because of the tracking the edges are virtually worn down.
    Based upon these pics, would you replace them now or wait? I can get a deal at Costco.
    Live your life as if nobody is watching you.
    Chugger
    North Devon
    2,716
    I'd get it tracked, and leave them on, might see a couple of thousand miles out of them
    57 A3 2.0 TDI Sportback (140)
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    I change mine at 3mm, piece of mind really with all the rain we are getting at the moment, I'd get them changed or move them to the back
    Apr 2012
    N. Wales, LL22
    1,224
    i'd keep using them, are they directionly or outer facing?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    2,230
    Quote Originally Posted by Ste_Nova View Post
    Not sure about that question. I only know that they are the front 2 of a set of 4 that I bought over a year ago.
    Apr 2009
    Coventry
    2,219
    The outer edge that is worn was never the 7mm depth when new.A minimum of 1.6mm in a continuous band throughout the central three-quarters of the tread width, throughout the whole of the circumference is legal, so scuffing of the outer edges is permissable.Its recommended that you change out at 3mm.Your tyres should be fine for quite a while.I personally change mine at about 4mm.If you can get a good deal now, then why not buy em and wait till they need changing? Win/Win as youll have to buy some eventually! If you are going to get it tracked, make sure its a 4 wheel laser job, and not at the likes of kwik fit.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    2,230
    Been offered a pair of Goodrich all in £101.14 each.
    Tyre is 235/45/17/94y
    What do you reckon?
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    235? thought the 17's were 225
    2,230
    Yeah, 235.
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    not heard much about them tyres, you can get a pair of Avon Zv5 on here for £85 each
    http://www.camskill.co.uk/m54b0s312p...17_235_45_R_17
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Don't forget that 'legally' you only have to have 1.6mm across the *Central Three Quarters* of the tread, as long as the shoulder isn't worn to canvass you'll be ok.
    Of course some people opt to replace before this stage, but quattro's often wear the shoulders out.
    2,230
    Don't forget that 'legally' you only have to have 1.6mm across the *Central Three Quarters* of the tread, as long as the shoulder isn;t worn to canvass you'll be ok.
    Cheers James, I panicked for a bit when I saw the edges nearly worn, but sleep a bit easier knowing the tread is at least 3mm across the middle of the tyre.
    I will probably go for the Goodrich tyres from Costco. But I will leave it for a month. I think they are American, but they seem to have a good rep.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    not trying to hi jack the thread but do folks still rotate the tyres? went to costco... they wanted to put the back tyres on to the front as it is the policy.. talked them around to leaving the back ones on as the were 6mm but the boss comes out and says they need to go on the front.. so i cancelled the order.... all i wanted was some more meat on the front end as im down to 3mm and the apr tune means that will probably be 2mm by next month.
  1. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  2. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
  3. What tyres for my S3 ??
    By sidicks in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2003, 15:54
  4. bumps in tyres
    By phloat in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 09:08
  5. Tyres?
    By Moresauce in forum Other Brands & Models
    Last Post: 16th January 2003, 19:57
