Monster MotorsportChris Nott
Results 1 to 13 of 13
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question 2 Flush or not 2 Flush, That is the Q !
    When you do your own oil changes,
    Do you use/do an Engine flush 1st and then drain all the old oil out or do you just drain out the old oil and let the old oil bits stay in the nooks and cranny's as they say?
    in my older cars it was sometimes wise not to as you may clear out oil sludge that was doing some good, good old fords, lol
    your views ?
    Turkster's Avatar
    Dec 2007
    2,723
    anyone ?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Passat TDI on 192k miles, never flushed it ever, just regular oil changes. The fresh oil goes black as soon as you pretty much drive down the road, no doubt mixing some of the old stuff on the way. Not familiar on a 2.5 though.
    Gazzago's Avatar
    May 2012
    61
    Dunno mate
    I have used engine flush in the past but just wonder if it causes more harm than good....
    I'm wondering if I should use it on my next oil change too!
    Jul 2007
    London
    3,235
    Give it a miss and spend your money on a good quality synthetic oil, as they have better detergents and will clean the engine properly inside. I have rebuilt many v6 tdi engines with 170k-300k and there was zero sludge built up in the engine. The reason the fresh engine oil goes black in minutes is the fresh oil mixes with the oil left in the oil cooler which cannot be drained normally when doing a change.
    For a thorough flush (1.8T engines for example) i drain 1-2L of oil and fill with 2-3L of diesel then run the engine at a fast iddle for 10 min. or so then drain and fill with good oil then repeat in a week.
    FOR SALE:
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,478
    id never flush an audi
    it loosens all the crap (if any)
    and could and will block the pick up
    boost-addict's Avatar
    Aug 2011
    977
    Well more so a diesel kersene mix. But thats what is in a tin of engine flush
    Next time you happen yo buy some notice how it smells and looks like disel. Any way i wouldnt try unless your willing to risk destroying a perfectly working engine. I considered this last oil change but oil pressures are fine so why muck about with it. New oil anf be done. Oh and use decent oil. I use castrol edge 0-40. On trade was 40. But should be 58.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    I'd never be using engine flush m8... Once seen a kid use engine flush and thought he had to get the engine hot so within 5-10 mins the phone was ringing as he seized the engine and needed towing back...if it waters down the oil that much to destroy a engine in such short time then it won't be going in mine.. It was a good make no cheapo rubbish brand.... Best thing was it was a v6 conversion in a Astra so lots of time and money spent to do this job when it was first done.....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Aug 2011
    977
    i bet you find he was reeving it. what ever happened he didnt follw the instructions
    Turkster's Avatar
    Dec 2007
    2,723
    well i did the flush the other day, i cant say i noticed any real difference, put it all in when the engine was hot, let the engine tick over for 5 mins and then revved it for another 5 mins at about 20k revs, switched off and drained all the old oil out, to be fair, my oil is changed every 10k miles and has been for the last 5 years, all the oil that came out was none lumpy or had any crap in it, i had a stir around in it and scrapped the bottom of the collected oil pan, all was good, I replaced the oil after it had fully drained with 5 40 fully synthetic long life oil and changed the oil filter, I used 5.5 Ltrs, fired up the Quattro and all is well, I must say that the car seems to run a bit smoother now and seems to pull a bit better too, maybe its all true or its just the mind set, who knows, I even managed to reset the service indicator. Cost me £50 all in, not £150 at the stealers,
    _G_
    _G_'s Avatar
    Jul 2011
    869
    out of interest what engine flush did you use?
    Chugger
    North Devon
    2,716
    iv sometimes used engine flush... usually only forte engine flush.
    I flushed my old 1.8t right before dropping the sump to check the pick-up... bearing it mind it had been on avs all its 90k/10 yrs old... and it was clean as a whistle. Not scientific, but cars iv flushed before are still going strong...
    i seriously doubt it does any harm, and it would clear any kind of build up which could (unlikely) stop the engine from being properly lubricated/cooled.
    57 A3 2.0 TDI Sportback (140)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    I've used flush cans before without issue. Usually only if i dont know the history of the engine though. My own cars get oil changed every 5k, so they stay very clean.
    I've also used a 50:50 mix of diesel and cheap engine oil on a very sludged up 1.8T i bought for my track car. When i got it off the trailer it sounded like a bag of spanners clacketing away. Drained the old oil out and it came out in ACTUAL lumps. Filled it with 50:50 diesel/oil and whacked a new filter on. Started it and held revs at 1500rpm. After about 6-7mins one by one the lifters all got pressure and quietened down. By 10mins it sounded more or less normal. Drained that lot out, and refilled with more of the same, repeated the process, then drained and filled with cheap mineral oil and a new filter, and it sounded perfectly quiet. Oil pressure was a bit low once up to temperature, but thats to be expected as its a high mileage motor. I'll pop the sump off and fit a new pump before it goes in the car.
    TD5 Land Rover Defender build
  1. REMAP OR NOT REMAP THAT IS THE QUESTION
    By DEMON JAMS in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2009, 00:27
  2. To replace gearbox or not to that is the question?
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2007, 17:26
  3. S3 or not S3 - that is the question
    By Felon in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2007, 17:23
  4. Evo or not to Evo that is the question
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2004, 12:12
  5. Chip or not to chip...that is the question...
    By jugman99 in forum A8/S8 forum
    Last Post: 22nd December 2003, 23:57
