EM TuningSky Insurance
Results 1 to 9 of 9
    dantdi's Avatar
    Feb 2008
    kent
    511
    JD Cambelts Near Canterbury
    Hi all,
    It's time for Cambelt change for me. Just wondering if anyone used know anythink about JD Cambelts?
    JD Cambelts. Cambelt Replacement Service for Canterbury and East Kent
    Or
    Thinking going with S-line in Ashford. But was bit put off by them saying Dayco makes belts VAG OME parts.
    www.s-lineautomotive.co.uk/
    Every else saying Dayco is NOT ome part for Audi. Or not heard them.
    2 places saying dont like using Dayco belts.
    Dan
    Jul 2007
    London
    3,074
    Dayco,Gates and Contitech are making belts for Vag group. I would only go with dayco on a 4 pot engine, i had a Dayco belt snap on my own car at the joint line 3k after i've rebuilt the engine... Bought the car with worn camshafts and previous owner had a garage fit the cambelt kit, i just did not change the belt as it looked new to me and had only few miles on it. It was painfull rebuilding the v6 tdi engine, new heads, new cams amongst other things but the most time consuming was replacing the crankshaft housing, the belt curled and sheared the top off causing the engine to dump all the oil on the floor- brown trousers moment as i thught the engine hydrolocked and thrown a rod trough the block !
    FOR SALE:
    Jul 2007
    London
    3,074
    If you don't mind travelling to N. Londont then i could do the cambelt for you at "mates rates"...
    FOR SALE:
    dantdi's Avatar
    Feb 2008
    kent
    511
    Ah right! Thanks Adam. Now your 2nd one to tell me they have had Dayco belt snap on them. Think i'll avoid Dayco even tho my A3 is Only 4cly.
    Can you recommend a good make? Or just go to Audi buy akit Job done?
    Also JD Cambelt say they change the Studs?? when doing the cambelt. Whats the studs?
    Thanks for your offer mate, But at mo just to busy with work. Just looking place can take it leave it and pick it up after work.
    Your bit to far for me.
    Jul 2007
    London
    3,074
    Contitech cambelt kits do come with new studs for the tensioner and relay rollers- they are stretch bolts and some shear if not replaced. They are not supplied on every engine just the ones prone to fail !
    FOR SALE:
    Jul 2007
    London
    3,074
    I understand what you're saying but i had folks travel over 250 miles just to get a job well done ! I would not mind travelling 50 odd miles just for piece of mind ! I would make sure the garage replaces the water pump whilst at it !
    FOR SALE:
    joedredd's Avatar
    Dec 2009
    Bexleyheath, Kent
    100
    dantdi, adamss24 (Chris) is a top bloke. He has done several jobs for me on my 98 A6 and he has already done 1 job for me on my new purchase, and will be doing my EGR valve for me soon as well.
    EDIT; Chris empty your PM box mate trying to send a message to you
    1998 A6 Avant 2.5TDI Retired at 185k miles
    2006 A6 Avant 3.0TDI S Line Quattro
    dantdi's Avatar
    Feb 2008
    kent
    511
    Picking up parts tomorrow for the cambelt.
    Im getting
    Cam belt kit
    Water pump (metal impeller)
    Aux belt
    aux belt tensoner
    What should i get in the cambelt kit?
    What new bolts will i need to get?
    How much G12 coolant do i need to refill the system ?
    dantdi's Avatar
    Feb 2008
    kent
    511
    Anythink else i have missed off?
  1. cambelts!!!
    By sainte986 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2008, 12:20
  2. Cambelts...[NOT AGAIN!]..you might find this interesting...
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2008, 16:31
  3. cambelts
    By cawood in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2007, 14:24
  4. TDi Cambelts
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th October 2005, 09:57
  5. Cambelts....can we all agree?! (LONG)
    Last Post: 1st October 2004, 10:05
