Thread: Engine Oil -
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Engine Oil -
    Afternoon -
    Engine oil is one of the areas that I spend a while researching - reading up on.
    I consider it "the" most important part of a car due to the job it does - lubricating & keeping the engine clean.
    I am just curious as to what brand & type of oil people use on here?
    At the minute I am using Shell Helix Ultra 5-40 in my 2.5TDi.
    Just looking at finding out what people have used / use and what their thoughts are.
    I also usually change my oil and filter every 5/6k - currently toying with the idea of moving to an ester based oil as opposed to a mineral base-stock.
    Sep 2010
    498
    I use Castrol, the gold bottle stuff. 505.01 I think for the PD130 engine.
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    333
    If you can use an ester based oil, it will give the best protection. What year is the 2.5tdi?
    Tim
    Use the code AUDIS and get 10% Club Discountoilman's website for VAG engine oil and much more - register for news and offersemail: sales@opieoils.co.ukphone: 01209 202944
    a3sline_nottingham's Avatar
    Mar 2012
    64
    i have a 2ltr petrol FSi SLine - can anyone recommend the best oil for mine too please
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    333
    Is it standard/modified and road/track/mixed use?
    Tim
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Valvoline SynPower XL III (5w-30)
    Researched it to death using various websites and experimenting as well. Used to use Castrol Powerflow III... which was later replaced by Edge I believe... and personally the Powerflow III was quite good but the edge burns more quickly... and gets dirty more quickly...
    I have used Valvoline for the last 8k miles and changed twice every 4k miles... I think I've found the right oil for me.
  1. 1.9 engine oil??
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2011, 21:27
  2. Engine Oil/Gearbox Oil?
    By Murf in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2011, 01:31
  3. engine oil change should i get a genuine oil filter
    By dusty in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2011, 15:50
  4. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  5. Checking Engine oil with engine running?
    By Defratos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2007, 18:27
