UnicornAdrian S Flux
    Jan 2012
    Post Thanks / Like
    A5 3.0TDI - Faulty Inlet Manifold - HELP!
    I recently took my 3.0TDI into Stoke Audi for its 40k service. Everything was OK until they told me that their systems were picking up a faulty manifold! the car is DEC 2007, mostly motorway commuting, so I'm pretty sure the manifold shouldn't be faulty already?!
    I have used VAGCOM to make some minor tweeks, mostly things like dipping wing mirror when in reverse, but I have accessed the Audi Drive Select (ADS) - this has options to change the engine and steering response.
    So I have a few questions for you all:
    1) Has this happened to anyone else?
    2) Could the ADS be affecting the diagnostics? - and by removing this part through VAGCOM the system would read as normal?
    3) What are the chances of being able to get Audi UK to cover the cost if it is genuinely faulty - even though I've changed the base coding with VAGCOM? (This is my fourth Audi and I'm 24 - and so I thought of playing along the lines of brand loyalty)
    ANY help would be greatly appreciated as I'm looking at a bill of £1300 to get this repaired.
    Also - does anyone have VAGCOM in Chorley/Preston/Bolton/Wigan/Eccles/Monton/Warrington areas? - may be worth removing my ADS and having a diagnostics check to se if it makes a difference?
    Thanks, Andy
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    Look for threads 'inlet manifold runner' common problem
    A4 (b6) 2.5 TDi QS Saloon.
  1. Inlet manifold?
    By vince, A3 turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2011, 07:40
  2. Inlet manifold.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2011, 23:14
  3. S3 inlet manifold
    By S3 AJ.X in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 17:19
  4. Inlet manifold (A3,S3)
    By emery1990 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2009, 20:22
  5. Inlet manifold help
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 10:06
