JuicyDTUK
Results 1 to 18 of 18
    Aug 2011
    London
    16
    Post Thanks / Like
    need help with re-map or tunning-box for 2.5V6 TDi
    I'm looking to get my Skoda Superb 2.5 V6 TDi done.
    not sure where to go and who would be better to give me the right answer
    which is better and why?
    and how much is it ?
    and how much difference did it made ?
    Jul 2007
    London
    1,574
    Post Thanks / Like
    I have a Steinbauer tuning box for a 163Bhp engine wich i believe your's is, i was using that on a AKE 180 bhp without issues just a touch smokey...the box is fully adjustable and it does what it says on the tin ! Drop me a pm if interested, swapping the v6 tdi engine to a 1.9 tdi which will require custom mapping hence it's not needed anymore. The beauty with the tuning box is you can remove-it at any moment and can be sold to get some money back !
    FOR SALE:
    Aug 2011
    London
    16
    Post Thanks / Like
    Quote Originally Posted by adamss24 View Post
    that would be nice but my one is 2002-reg and running 114KW (150 bhp)
    Jul 2007
    London
    1,574
    Post Thanks / Like
    110kw = 150Bhp, your's is a 163Bhp !
    FOR SALE:
    Aug 2011
    London
    16
    Post Thanks / Like
    power conversion - converting units of power, horsepower, ps, kw, hp, bhp
    try this link
    Aug 2011
    London
    16
    Post Thanks / Like
    Jul 2007
    London
    1,574
    Post Thanks / Like
    What's the engine code ? You might have a very old engine designation wich was 155Bhp engine code AYM ? Audi dropped the 150Bhp lump from 2000 as it's been replaced by later 180Bhp engines (in quattro guise) and the FWD models got 155Bhp engines then later ones went to 163Bhp in the cabriolet and allroad alongside the 180Bhp lumps (they got revised heads with cam rollers)...However the box still works fine on your engine as the difference is only in the tune/map !
    FOR SALE:
    Aug 2011
    London
    16
    Post Thanks / Like
    my one is skoda superb 2002-REG
    just looked at the log book :AYM011218AYM
    So are you saing they are old and not good engines ?
    just wish to find out what is the difference ?
    Jul 2007
    London
    1,574
    Post Thanks / Like
    AYM is a detuned version of the AKE 180 Bhp engine, they are good engines. The difference is rods, injectors, injector pump, mapping and a few more bits and bobs. The AYM has been designed as a Euro 4 version of the old AFB 150 Bhp engine...There might be a few more differences wich i can point only by comparing them side by side, still tuneable in every respect.
    FOR SALE:
    Aug 2011
    London
    16
    Post Thanks / Like
    so my engine : rods, injectors, injector pump, mapping and a few more bits and bobs, are not that strong ? ???????????
    Jul 2007
    London
    1,574
    Post Thanks / Like
    The 150Bhp tunes well to 180-190 Bhp with just a remap or tuning box. When audi introduces a new, more powerfull engine they do things a little different hence they use stronger rods, lower compression ratio, larger nozzles and optimised ECU program and often a different turbocharger. They don't just chiptune or remap their existing models ! Quattro models also get a better injector pump wich can pump more fuel at higher pressure and also larger nozzles as well !
    FOR SALE:
    Aug 2011
    London
    16
    Post Thanks / Like
    well, my main idea to get it running better so i get more MPG out of it but if i get more power and torque then I'm double happy
    Aug 2011
    London
    16
    Post Thanks / Like
    even thou i said MPG is on my mind ,
    i'm still thinking of Pipercross panel air filter, De-cat, Re-map,-40mm Springs and may be 19" wheels
    Aug 2009
    46
    Post Thanks / Like
    i fitted a tuning box to my a4 163 cab though have again removed it is a psi motorsport one and was £500 worth if you dont get sorted i will sell it,its for the bosch vp44 pump
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    The Unit
    15,238
    Post Thanks / Like
    Are you over on Briskoda? Why not an STS unit via Shark?
    Aug 2011
    London
    16
    Post Thanks / Like
    Quote Originally Posted by N8 View Post
    Shark dont do unit for 2.5 tdi
    how much for coylis for my superb 02-reg ?
    yes i'm am on briskoda !
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    The Unit
    15,238
    Post Thanks / Like
    They don't do a map for your car? I'll find out.
    Aug 2011
    London
    16
    Post Thanks / Like
    ifound the tun-box from tdi-tunning but its way out of my budget for £450
