GNJVAG Check
    Jul 2011
    Post Thanks / Like
    Post New 2009 Polaris Ranger™ RZR™ 800 S ATV F/S
    We supply and deal with all kinds ATV and UTV Equipment.
    You can contact us for the price of any of the below equipments.
    Can-Am™, Arctic Cat, Cub Cadet, E-TON, Honda, Hyosung, John Deere,
    Kawasaki, KTM, Kubota, KYMCO, Polaris, QLINK, Suzuki, Tomberlin™,
    United Motors, Yamaha.
    For Bookings and more information on our Sales and services
    Contact us via ........
    Engine
    Engine Type 4-Stroke Twin Cylinder
    Displacement 760cc High Output (H.O.)
    Fuel System Electronic Fuel Injection
    Cooling Liquid
    Drivetrain
    Transmission/Final Drive Automatic PVT P/R/N/L/H; Shaft
    Drive System On-Demand True AWD/2WD
    Suspension
    Front Suspension Dual A-Arm 12" (30.5 cm) Travel
    Rear Suspension Dual A-Arm, Rolled with Anti-Sway Bar 12" (30.5 cm) Travel
    Brakes
    Front/Rear Brakes 4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
    Parking Brake Park in Transmission
    Tires Wheels
    Front Tires / Model 27 x 9-12; ITP 900 XCT
    Rear Tires / Model 27 x 11-12; ITP 900 XCT
    Wheels Cast Aluminum
    Dimensions
    Wheelbase 77" (196 cm)
    Dry Weight 1,000 lb (454 kg)
    Overall Vehicle Size (LxWxH) 104 x 60.5 x 70.5" (264.2 x 153.7 x 179 cm)
    Ground Clearance 12.5" (32 cm)
    Capacities
    Fuel Capacity 7.25 gal (27.4 L)
    Bed Box Dimensions (LxWxH) 22 x 42 x 6.5" (56 x 107 x 16.5 cm)
    Box Capacity N.A./300 lb (136.1 kg)
    Payload Capacity 740 lb (335.6 kg)
    Hitch Towing Rating 1,500 lb (680.4 kg)
    Hitch/Type Standard/1.25" Receiver
    Features
    Cargo System Lock & Ride
    Lighting 55W low/ 60W high
    Electronic Power Steering Not Equipped
    Instrumentation Digital Gauge, Speedometer, Odometer, Tachometer, Tripmeter, Hour
    Meter, Clock, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, DC Outlet
    For Bookings and more information on our Sales and services Contact us via email ........
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,988
    Post Thanks / Like
    I'll give you the benefit of the doubt that you've not signed up here just to advertise..... but if so then please contact site admin to discuss advertising rates.
    Thank you.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
