Chris NottBadger5
    Rear wheel sensor half off!
    Off side rear wheel sensor.Only half off!
    Hello people. Got it scanned and Audi diagnosed it as the rear off side wheel sensor as guessed by many of you.
    I got to replace the rear wheel sensor on my '99 TT but am having real trouble getting the old one off. I've managed to get the 5mm hex allen key head thingy out from the back of the hub and assumed the sensor should now just pull out of the hub, but it's stuck fast and as it's quite inaccessible I can't lever it out. Am I missing something or is there a knack or trick to removing the sensor?
    P.
    Lewis583's Avatar
    Mar 2010
    872
    Every wheel speed sensor i have came across at work has been a pain in the ass to get out. As far as i know there ain't a trick just plenty of WD40 or similar, and gently work it/ twist it back and forth
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Fair enough!
    Cheers!
