Evolve have been using and testing Intrax springs for well over a year and have decided to offer the entire range based on the excellent results.
Intrax Lowering are made to the highest standards possible according to DIN2095.
Only the highest grade of chrome-silicium wire is used.
For all most any model of car we can supply a set of lowering springs. The average lowering with these springs will be around 25 to 35 mm.
Also available is extra lowering for those wanting lower a little more.
Intrax are regarded as one of the best suspension companies in the world most well known for their high-end range of coilovers.
Alot of research and developement goes into these springs and it shows when you see individual types of springs made for cars with the sports/s-line packages lowering a sensible amount.
Spring rates are also designed for comfort aswell as improved handling.
Intrax springs work exceptionally well the Bilstein B8 Shock Absorbers.
The springs are available for a wide range of VAG's and are well priced for such a high-end brand.
Full listing will be put up shortly.
In the mean time if you have any questions please do not hesitate to ask.
LinkBack URL
About LinkBacks
