Hi,
Could you give me a price for the dogbone bushes for a A3 3.2 and the basics on removal.
Kind Regards,
Jonathan
Hi,
Kind Regards,
Jonathan
Morning,
The front engine mount large insert is £16.71 and the engine mount is £19.31. Both are a straight swap by removing the old ones that are bolted in, a press isn't needed so it's not too hard of a job.
Damian @ DPM Performance
DPM Performance
W: www.dpmperformance.co.uk
T: 01207 561606
E: sales@dpmperformance.co.uk
Cheers for the reply.
Are these powerflex items?
Have you any comments regarding added vibrations after fitting these?
They are yes.
You will get slightly more vibrations when ticking over but this will reduce as they bed in.
DPM Performance
T: 01207 561606
Hi,
Just read this.... http://forums.vwvortex.com/zerothread?id=4195875
If the powerflex large bush just a push in job i.e doesn't need the subframe taking off???
Morning,
No it's the same as in the thread.
http://www.dpmperformance.co.uk/powe...03-p-3916.html
DPM Performance
T: 01207 561606
I mean't to fit the large or small bush does the subframe need removing? As per the link?
Sorry I was meaning yes it's the same fitment process as in the thread you posted.
DPM Performance
T: 01207 561606
