Hi Damian
Does this set include 4 or 5 bolts?
Scott
Hi Damian
Scott
Hi Scott,
It includes 10 bolts.
Damian @ DPM Performance
DPM Performance
W: www.dpmperformance.co.uk
T: 01207 561606
E: sales@dpmperformance.co.uk
Hi Damian
That's what I meant
Will be ordering in a sec.
Scott
Thanks Scott!
DPM Performance
T: 01207 561606
They've arrived, thanks Damian A+
No problem Scott, thanks again for the order.
DPM Performance
T: 01207 561606
Hi Damian
Cheers for the advice earlier on the phone. I used a long screwdriver to get it off, gave the hub a clean, repeated this a few times and finally went on OK.
Had the fronts fitted aswell when I took the car in to have the coilovers adjusted, since they had the wheel off anyway. It's all good.
Do you know which locking wheel nuts are suitable with the bolts you provided, as I'm under the impression if the locking nut is longer/shorter or different weight, it can send the balancing out and cause vibrations. Not sure in the truth in this?
Scott
No problem, glad you got them on.
Yeah that's right. On the front you have 14x1.5x37mm and on the rear you have 14x1.5x40mm. You should be able to get them direct from McGard.
DPM Performance
T: 01207 561606
