Revo TechnikJuicy
    Jul 2006
    127
    Post Thanks / Like
    Handling mods advice
    Hi,
    I'm looking at mods to improve the handling of my Audi A3 2.0T S-line Quattro.
    So far I'm looking at H&R 35mm cup kit's and H&R ARBs. Is there anything else you would suggest doing at the same time? Bushes maybe? The car is 3 years old but has only done 7500 miles.
    Also I'm slightly confused by the naming of things when looking at the H&R website, would I right in saying the the 35mm cut kit is the touring kit and that the ARB is the same as a sway bar?
    Thanks,
    Jeff
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,692
    Post Thanks / Like
    Morning Jeff,
    I'd also look at the H&R dampers as well over the likes of bushes unless any are particually worn and need changing.
    The full kit will provide a better ride and also work better together over standard dampers and lowering springs.
    http://www.dpmperformance.co.uk/hr-3...03-p-1142.html
    If you did just want the springs these are the ones you need and the ARBs are in the link below them:
    http://www.dpmperformance.co.uk/hr-3...803-p-640.html
    http://www.dpmperformance.co.uk/hr-2...903-p-281.html
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
