Sky InsuranceRevo Technik
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Post Thanks / Like
    Eibach ARB's & Eibach Springs for S3 (8L)
    Hi Damian,
    Just looking for springs and ARB's to go with the bilstein B8's i bought from you a while back.
    I can't seem to find many reviews of the ARB's yet and wondered if you'd fited them to any S3's and what the end result was?
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,692
    Post Thanks / Like
    Morning Mike,
    We seem to sell a lot to the R32 drivers but with the rear being quite big at 24mm it seems to match the front 26mm bar a lot better and gives a very good handling car. Be aware though, you can get a fair bit of lift off oversteer
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Post Thanks / Like
    Hi Damian,
    I'm trying to get the car to be as neutral as possible really and if it can make a R32 lift off oversteer I'm not sure what it'd do to the S3!
    I thought about the H&R ones as well but it's still a 4mm difference between the front and rear bars (I'm aiming for 3mm so it's a proportionally larger rear bar). The only ones I can really find are Neuspeed being 22m front & 19mm rear (but they cost a small fortune) - Are there any others you could suggest?
    Mike
    S3 AMK
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,692
    Post Thanks / Like
    If you want it more neutral then I'd say go for the H&R's, that's also what we ran on our S3.
    DPM Performance
    T: 01207 561606
