Eibach Pro Spring Kit.
Dazmo
Leicestershire
Do you supply these for my 2006 Audi A4 3.0 TDI Quattro?
Im after the eibach pro spring kit, 30mm all round.
I beleive the part number is E10-15-003-03-22
Can you please confirm correct fitment and price.:o.k:
Yeah we'll beat that price and do them for £150 inc. VAT plus postage.
Damian @ DPM Performance
Does that include any kind of club discount and how much is postage as a difference of £2 is neither here nor there?:shrug:
If you could do them for £140 with postage then ill have a set off you:icon_thumright:
Otherwise ill nip down graham goodes as they are local to me and collect some.:racer:
No we couldn't do that price, sorry.
Thanks for asking though.
Hey damian,
I have a question and its something i didnt realsise before but...
Obviosuly i have an S-Line A4 and it is already lowered 20mm by the standard springs so is it really worth going ahead with 30mm eibachs when the only gain i will receive is a 10mm drop from the standard S-Line springs?
Will it make that much difference or should i maybe go for the 40-50mm springs but i dont want it to be too low.
Ive heard that the 30mm springs are more comfortable than the standard s-line ONES
The Eibach pro's will be a better quality spring but will only lower your S-Line around another 10mm so if you're wanting more of a drop you'll need to go for something like the H&R 45mm springs.
Is there anything with a 40mm drop and also will these affect the standard shocks/dampers or will i need to uprate these? can i manage on standard shocks/dampers
No but Weitec offer a 35mm drop.
It would be best to change the dampers as well as it'll give you a better and more matched ride but a lot of people just use lowering springs with standard dampers and have no problems.
Ok thanks mate,
Dont suppose you have any pics of an s-line on 45mm springs do you?
And how much are those H&R 45mm springs?
We'd do them for £152 all in.
Cheers Damian, how do i order then mate?
Would i be ok to use these on my standard shocks as they have 50k on them , or would it be wise to put some new standard shocks on as i cant afford eibach dampers.
You can either order online and put a note saying 'Att: Damian' or just give us a ring.
It would be best to save up for a set of after marker dampers with shorter pistons really as they won't be that much more then a new set of standard ones.
Damian sorry to keep pestering you mate.
But would i be better off going for the weitec GT shocks and springs? And also whats the difference between the hicon and the GTs
Are weitec shocks hydraulic?
3K
DPM
14
2K
DPM
DPM
