Badger5Sky Insurance
Results 1 to 8 of 8
    Feb 2013
    Wiltshire
    346
    Suspension recommendations for B7 S4
    One of my stock dampers has started leaking, so its soon time to replace. What suspension would you recommend for my car? Its a road only car, but I might be taking it on a track maybe once a year. But only for a couple of laps. The majority of use of the car is crappy uk roads and high speed motorways (most people overtake you if you are 80mph or less here!). I would be fitting them myself, and I have no knowledge on setup, so would need them to be pretty simplistic. Also want them to last, so stainless steel would be prefered.
    Thanks!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Afternoon,
    Are you looking for coilovers or springs and shocks?
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Feb 2013
    Wiltshire
    346
    probably coilovers really, but would consider anything that suitable and not crazy expensive.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    To be honest you'd struggle to find a springs and shocks kit for the S4 B7 and all the coilover kits we have available are £900+.
    Coilovers : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts for all VAG vehicles at the best possible prices.
    Bilstein have dampers available but you'd then either need to use your standard springs or go for a set of lowering springs as well but this would also be at least £600+.
    Unfortunately nothing for the S4 is ever cheap.
    DPM Performance
    T: 01207 561606
    Feb 2013
    Wiltshire
    346
    I do like the pss kit, and the eibach kit too. I take it both are pretty good setups?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Very good set ups!
    DPM Performance
    T: 01207 561606
    Feb 2013
    Wiltshire
    346
    Ok, so I am getting closer to the point of having time to sort suspension. Been quoted £100 a corner for dampers only from Audi. Plus that again for upper control arms. What spring/damper combination would you recommend (not coilover) that would be good performing for road, slight lowering abilities and wont break the bank?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Morning,
    We don't have any springs and shocks options for the S4 but we have the Bilstein B8 dampers for £540.00 inc. VAT and delivery which you could match with a set of springs from Eibach or H&R but this is going to take the total to around £700+.
    Bilstein B8 Sprint Damper / Shock Absorber Kit A4 B7 Avant / Saloon 2.0T FSi Quattro, 2.0TDi Quattro, 3.0TDi Quattro, 3.2 Quattro 01/05> - £540.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of a
    If you wanted a cheaper option then Bilstein also offer the B4 dampers for £360.00 inc. VAT and delivery and again you could match these with a set of H&R or Eibach springs to bring the total to around the £550 area.
    Let me know which sounds better and I'll get some set prices.
    DPM Performance
    T: 01207 561606
  1. Spax suspension kit for a 1.8t will it work on 1.6
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2004, 16:21
  2. Brake & Suspension upgrade for A8
    By imported_WIL9598 in forum Handling
    Last Post: 11th August 2004, 11:15
  3. Recommendations for Revo fitter.
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2004, 11:37
  4. Suspension mods for 1.8T
    By Aurom in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 21:44
  5. What would you recommend for a runabout?
    By jxm96c in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2004, 09:53
