DNA TuningSky Insurance
    HerefordQuattro's Avatar
    Hereford
    250
    Post Thanks / Like
    2.5tdi engine cover
    fiddling with the plastic cover on my 2.5tdi today as it was cracked when i bought it, only gone and made it worse i.e crack is now a hole!! So i've left it off as doesn't seem to do much apart from stop you seeing more engine? Where is best place to get replacement ?
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Mar 2010
    10
    Post Thanks / Like
    Mine also has some padding on the underside so I'd say it also has a noise reduction function. If you don't notice or mind the car being any noisier then I'm sure it will be fine without it.
    I wouldn't like to guess how much a new one would cost from a dealer.
    Hereford
    250
    Post Thanks / Like
    Yes had noticed the padding but with the bonnet down the noise difference is nothing (sounds like a tractor anyway)
    have also noticed oil / diesel? run off the padding on the tab that covers driverside cylinder head, which is worrying so better keep an eye on that
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    747
    Post Thanks / Like
    Mine does the same but its a very small amount and i have never managed to find where it comes from. Whilst investigating it a while back i found that the overspill pipes on the injectors had perished so that got fixed but never found the source of the oil.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap= need another dyno run
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip
    1988 Yamaha FJ1200 120hp
    Hereford
    250
    Post Thanks / Like
    bump
    anyone got a 2.5tdiv6 engine cover for sale?
