Pump maxed out? I runned over 200hp with stock nozzles. Proper remap and enuff air should do the trick...my goal is ~180kw.
Current charger is maybe too small (2556) for even reaching that 180kw. That we will see later. I'll dyno my current setup on
next weekend. I'm not sure are my nozzles the same you mentioned, because this engine has bit different nozzle holders than AFB.
Stock nozzles were 142P795 5x0.18 and I believe the new bigger ones are from Iveco/Cummins truck (143P970 8x0.16 holes).
Same nozzles will not work on AFB and AKN, even the engines are more or less the same.
What comes to rough idle - i put off the Econ button and the car runs idle smoothly . So ony tiny iq change needs to be done.
Whats the adaption channel and with what login code?
