Adrian S FluxGNJ
    Dec 2009
    36
    Post Thanks / Like
    Question Strange loss of power A3 Tdi
    Hi ppl got a new problem can anyone give some advice pls!!! My cars acting strange will be fine most of the time but if i put my foot down a little hard the car will go into limp mode. I'd have to pull over and restart engine and then it'll be fine. the problem happens randomly some times at 30mph sometimes 70mph.
    checked it on the vag com it can up with a pressure error some thing to do with pressure build up im not sure my mate did it for me as he dont trust a girl with his toys!!!!
    got told i need a new actuator but i cant get hold of one and would that even be the problem fix?????
    ANY ADVICE WOULD BE GREAT
    its a 2000 a3 tdi (AGR)
    TDI
    Dec 2007
    Bracknell, Berks
    64
    Post Thanks / Like
    It doesn't have to be actuator.
    Post some dynamic logs... Will be able to tell something more
    Professional chiptuning (most makes and models) and diagnostics (VAG, BMW, Vauxhall).
    Dec 2009
    36
    Post Thanks / Like
    Quote Originally Posted by etronic View Post
    Cheers etronic
    sorry im new to this what do you mean dynamic logs????
    thanks
    TDI
    Dec 2007
    Bracknell, Berks
    64
    Post Thanks / Like
    If you have access to VCDS get on the road and while accelerating you collect real time parameters.
    Do you have someone who knows about tdi diagnostics?
    Where about are you from?
    18,280
    Post Thanks / Like
    Quote Originally Posted by shaz A3 Tdi View Post
    Cheers etronic
    thanks
    Diagnostic logs, you need to get someone or buy the kit to scan the car to see if its most likely a boost issue, could very well be a caked up turbo with overboost issues, one of a number of things could be, get it scanned, check my sig link for users willing to help in your area, then come back & post your logs on here.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Dec 2009
    36
    Post Thanks / Like
    Thanks etronic i know a guy thats know a little ill see if can run some diagnostics, im from west london near heathrow
    cheers
