DTUKAMD Technik
    Jun 2009
    Post Thanks / Like
    low power A4 2.5 tdi
    hi im looking for some help- i have a 2000 A4 2.5 tdi quattro avant engine code AFB. it seems to be very low on power but its not "limp mode" as i have another car which does this and is very definite. i can hear the turbo spinning it just feels very sluggish. sometimes you can feel through the accelerator it almost wants to take off and give full power but is holding back.ive swapped from another car the same:MAF sensor,N75 valve, intercooler sensor.but it made no difference. no codes are logged on the ECU. Also the fuel consumption is pretty bad 18-20 mpg. dont know if its related but the coolant temperature dial sits around 70-75 degrees but i thought it should be 90.any help is much appreciated as ive gone through the forums and tried most things
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,988
    Post Thanks / Like
    Hi davey
    Have you had the car scanned for fault codes? Thats got to be a priority rather than try and make random guesses. The running temperature can't be helping things.
    Have you checked the turbo isn't sooted up? How many miles?
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Sep 2007
    North-East UK
    76
    Post Thanks / Like
    You could try changing the temperature sensor as it's reporting a low engine reading to the ECU and this may affect the power. Perhaps the engine limits the power/torque until it's fully warmed up?
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    978
    Post Thanks / Like
    the vnt turbo on these can coke up, its fairly easy to remove and de coke it and taking hot side apart to clean doesnt affect balance so its worth trying
    mine was sluggish untill i cleaned it now goes like a rocket
    mine didnt have any fault codes logged either
    with temp sounds more like thermostat than sensor, belts off job!!
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,271
    Post Thanks / Like
    the water temp could be the fault of the sensor. real easy to fix, cost about £30, if that fails then it could well be the thermostat being in the open position and not closing fully, my 2.5 had that issue,
    the thermostat is positioned behind the cam belt so its cam belt off to change that part, and then there is the water pump, which is a cam belt off job too,
    so if the temp sensor don't fix the issue then buy your self a new cam belt kit and get stuck in, or find a volunteer to do it for you,
    so if your water temp sensor is not giving the right reading then the cars ecu wont be telling the rest of the car what to do,
    Do you want £5k a month, every month, for working 3 hours a week part time ? I'm serious, open the link!
    http://www.makeandsavecash.com
    Jun 2009
    Post Thanks / Like
    ok, still have the low power problem but ive had it along a diagnostic company.he says there are no fault codes logged. He says when taking readings while the car is running the turbo is working ok, but the MAF is not getting enough airflow?? through it. ive tried a MAF off another car the same and it made no difference. hes checked the voltage from the MAF signal wire and its reading correctly. ive tried blanking off the EGR inlet pipe- made no difference. ANY IDEAS????
