hi i have an Audi 1.9 tdi red eye AFN engine year 2000 (w-reg)
iam have truble starting it from cold but when its runing its ok until its goes cold can anyone help. cheers![]()
You need to check glow plug operation and look for air ingress in fuel system.
FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
its had new glow plugs they working ok.
will check air ingress in fuel system i will let you know i i get on thanks
Are you sure the car is supplying 12 Volts to the plugs? I had one that had corrosion between the plug and the electrical connection causing the plug not to work correctly.
Is the resistance of the glow plugs should be less than 1 ohm?
Jim.
