hi i have an Audi 1.9 tdi red eye AFN engine year 2000 (w-reg)
iam have truble starting it from cold but when its runing its ok until its goes cold can anyone help. cheers
Are you sure the car is supplying 12 Volts to the plugs? I had one that had corrosion between the plug and the electrical connection causing the plug not to work correctly.
Is the resistance of the glow plugs should be less than 1 ohm?
Jim.
