DTUKDNA Tuning
Results 1 to 8 of 8
Thread: Boost increase
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    Boost increase
    I have a B7 1.9 PD115. I have a tunit, tuning box and K and N panel filter and has made 150.5 bhp and 270lb/ft torque which is, I think is impressive for the mods! I have a FMIC to pipe up but is pointless without a boost increase. How much can it safetly be increased by and how? Also what boost. Does it run as standard? My tuning box only increases fuel pressure
    If it's got t*ts or wheels, it's TROUBLE!
    evomaster3000's Avatar
    Dec 2004
    Bristol
    433
    Post Thanks / Like
    I'm having issues as my boost is high at the moment, 20psi @ max and the ECU don't like it and puts it in to limp mode.
    If i were u i'd invest in a proper re-map, this will sort out boost issues and do the lot properly.
    And upping boost on stock turbo is not a great idea as it's been designed to work at a specific range, take it out of that range it becomes less efficient, for you the 150pd upgrade parts, ie injectors, turbo, and the FMIC and then get a custom re-map.
    Try www.tdisport.co.uk, it's a good tuning forum, i'm on there, some knowledgeable stuff and tdiclub.com
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,254
    Post Thanks / Like
    Why do you think you need to increase boost to justify fitting a FMIC ? Fitting a FMIC is only going to keep your inlet temps down not make more power etc.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    PD140 ported head for sale
    Other car 500+ bhp MK4 Golf R32 turbo.
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    Quote Originally Posted by devonmikeyboy View Post
    To increase power!A small Boost increase will increase power! More boost means a more efficient intercooler to drop ACT's! I didn't want a smart arse post, I asked for answers. I'm guessing you don't know them so go be smart somewhere else!
    Feb 2007
    1,254
    Post Thanks / Like
    Quote Originally Posted by TorqueTerrorist View Post
    Sorry i don`t argue with idiots and my post wasn`t a smart ass one.
    Dec 2004
    Bristol
    433
    Post Thanks / Like
    Only if you have the fueling to match!
    A tuning box is a pretty naff tuning toy, it's only suitable as a cheap way to get a bit more power from a standard engine, and works well, but is in no way a tool to use for major power increase, as it's very crude!
    Diesels run lean as standard from the factory for emmisions, altering the amount of fuel going in ie richening it give more power but more smoke usually.
    Increasing boost will not work atall as the ECU has preset overboost settings and the car will go in to limp mode.
    Don't go messing with things u don't understand, I've been there and done it.
    Also the standard ECU is set up for stock intercooler, I have a feeling the new one on mine is less re-strictive and therefore running slightly higherboost after int, and the ECU don't like it atall, makes motorway driving impossible at speed as it goes in to limp mode.
    Marc1's Avatar
    Feb 2008
    719
    Post Thanks / Like
    I think you mis-read devomikeyboy's post, he wasn't being funny with you, he just asked a question and gave you some info, that's what the forum's for. If you've ever read the Audi Driver review on his car, you would know he know's a lot about tuning diesels. I think it's in his sig, if you're interested.
    Anyway, I think evomaster3000 has answered your questions now.
    Peace!
    For Sale
    B6 S Line Saloon rear bumper,B6 A4 Upper Grille,B6 1.9TDI catback exhaust,B6/B7 Full Piano black inlays,B6/B7 RNS E/GPS Sharkfin,B6/B7 Side airbags,B7 2.0TDI Intercooler and MAP sensor
    Jul 2009
    11
    Post Thanks / Like
    You don't need to increase boost just because you fit a FMIC. The better efficiency you should get from a FMIC will give you more power anyway due to cooler air and better flow. Obviously increasing boost will give you even more power, but it's not necessary.
    Loose the cockyness, it doesn't suit you!
    2003 A4 1.9 TDI Quattro Sport, 18" RS6's
