JuicyKowalski
Thread: waning lights?
    Mar 2009
    West Midlands
    57
    Post Thanks / Like
    waning lights?
    i got an audi 80 1994 tdi when u got the ignition on without the engine running i get the (!) light on and the water light flashing is this normall or is there a problem they go out once the engine is running and seems to go up to 90 on the temp n stay around there? any help would be good thanks
    Mar 2009
    West Midlands
    57
    Post Thanks / Like
    anyone? would be great help
    Milton Keynes UK
    243
    Post Thanks / Like
    Have you checked the user manual for what the water light is.
    Could be coolant or windscreen washer fluid level.
    Or maybe a faulty sensor. If there are only 2 wires going to the sensor then you can bridge them and check if the light comes back on.
    Regards,
    Jim.
    Mar 2009
    West Midlands
    57
    Post Thanks / Like
    i really should of checked that its apprently normal it flash's when on ignition without the engine running to signify its working
