UnicornVAG Check
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    Diesel dump valve query
    Having had petrol turbos and knowing pretty much how it all works just wondered what is so different about the vacuum system etc on deisels as i understand any dump valve on a diesel needs an electronic controller?? Any one know the ins and outs of this or am i a million miles away from the truth??
    I know its chavvy but the boy racer inside loves a dump valve piitisssssshhhh!!!!! Lol
    If it's got t*ts or wheels, it's TROUBLE!
    evomaster3000's Avatar
    Dec 2004
    Bristol
    433
    Post Thanks / Like
    I've fitted one on mine, not as good as ur petrol dump as sounds more like a sneeze but can be done.
    Need the obvious 50mm dump valve T, dump valve, a 5mm t off a boost pipe somewhere, a 3 way air solenoid thing and a microswitch activated on idle throttle postition. I've also fitted a switch so i can turn it off whan on cruise control.
    Basically if you do a search on the net for peugeot 306 dump valve fitting i found a useful write up just the only difference is you will need a boost pipe feed to keep the valve closed when on boost, and you will need to fit the microswitch to the throttle pedal in the cabin.
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    Thanks mate just searched that and learnt alot! Cheers
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    I don't suppose you have pics of how you did yours??
    Dec 2004
    Bristol
    433
    Post Thanks / Like
    will get u some soon
