Sky InsuranceJMB Retrofits
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    is it waterpump? awx engine TDI
    A4 1.9 TDI 130BHP 2001 B6.
    TEMP is half way reading 90 as always.never starts to climb.
    water in coolant bottle =cold even when engine hot.
    took expansion (coolant bottle cap) off and left it off, incase there was air in system.....no change.
    car is loosing coolant,cant see any leaks.......any ideas?
    807
    i dont really understand the problem...
    if it is loosing coolant i dont really know but my old polo had a problem with a cracked seal going into the engine... apparently a common thing to go.
    My local garage did a pressure check and replaced the part...
    Tetbury Audi Parts Man
    Feb 2008
    Gloucestershire
    260
    I would say water pump. They are very common to fail.
    Jun 2009
    Ipswich
    Have you anyone checked replaced theThermostat? Have you had the waterpump changed when timing belt changed?
