AH FabricationsEM Tuning
    APL TDi's Avatar
    Jan 2009
    285
    Please help! 2.0TDi problem
    Hi all
    I have a 2004 A3 2.0Tdi 3dr.
    It has gone into limp mode twice this week, so I took it to an audi specilist to have it looked at.
    It threw a code 16683 P0299
    It has only gone into limp mode when i am sitting at around 70mph, with no load on the engine what so ever.
    Has anyone else ever had this happen to them??
    Also do the turbos have variable vein geomerty??
    If any out there is in the know, please can you fill me in.
    A!
    Jan 2007
    Hampshire
    1,155
    Didnt your specialist have any clues?
    http://wiki.ross-tech.com/index.php/16683/P0299/000665
    Thats your fault code explanation from Ross-tech. Try following the suggestions they make.
    They do have variable vane turbochargers I believe.
    A6 3.0 TDI.
    APL TDi's Avatar
    Jan 2009
    285
    Cheers, il give it a go tomorrow
    A!
    Bing_IRL's Avatar
    Dec 2008
    Galway, Ireland
    34
    I had that problem once with a PD TDI Golf. Turned out to be a broken connection on a vacuum hose somewhere. Mine was fixed on warranty so I didn't have to worry about it but might be worth getting a soapy water spray out and have a look for any bubbles!
    Best of luck
