Volks AutosSky Insurance
Results 1 to 16 of 16
    denzelburner's Avatar
    Sep 2007
    Devon
    166
    changing the ecu
    Does anyone know if it is possible to change the ecu on a 2000 2.5 tdi 150bhp engine for the 2.5 180bhp engines ecu? or is it a completely different layout for the different engines. I ask this as a mate of mine has just bought an allroad 2.5tdi 180, and the engine looks exactly the same, and thought this would be an easy upgrade.
    If you can't beat them, arrange to have them beaten
    2000 B5 2.5tdi V6 (if only it were a quattro)
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Sadly I don't think it would be as simple as that.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Oct 2003
    up north...
    767
    there are several issues with changing the ecu
    1) may not be physically/electrically the same connectors / same ecu model
    2) the immobilizer would need recoding using the secret pin code to get the immobilizer and ecu to work together
    3) the 180hp mapping is probably wrong for a 150hp engine, although it would probably work if 1) and 2) were sorted it wouldnt be the best
    4) if your ecu is fine/working then just get a remap/tuning box for your 150
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Sep 2007
    Devon
    166
    thanks for both of those. It's a shame, as re-mapping the 150 I think gets up to 176, whereas the 180 would be near on 200.
    How easy is it to re-code the immobiliser to match the ecu?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    It's not a big job as long as you have the SKC's of both vehicles.
    Stu.
    Sep 2007
    Devon
    166
    SKC's?
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Secret Key Code
    Stu.
    Sep 2007
    Devon
    166
    Ah ha. Is there anyway of getting them, or is it a secret, lol. Surely the ecu coding wouldn't be too different to make it run that much worse would it?
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by denzelburner View Post
    Both engines use a GT2052V turbo BUT there must be some limiting factor as to why it isn`t safe to remap your engine to 180 bhp+ otherwise every company would sale a remap to that power. Your engine might have smaller injectors/clutch etc or a different cam profile. If companies remap your engine to 176bhp there is a very good reason for it.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Sep 2007
    Devon
    166
    Fair enough :-)
    Jul 2007
    London
    3,074
    Quote Originally Posted by devonmikeyboy View Post
    The engine block is identical, but the heads are different, the compression ratios are lower on the AKE, the turbocharger has a bigger compressor wheel altough the housing is identical but will stay on boost longer, the head is better designed- they have cam rollers as opposeed with cam followers, the injectors have higher opening pressures and 7 pin holes(6 on the 150Bhp), and the ECU map is more agressive. The MAP(Boost)sensor is also different-3Bar-and the injector pump is different. The intercoolers are stronger full alloy jobbies like the ones on rs4, slightly thicker than the 150Bhp model. The clutch is identical but the pressure plate has stronger fingers to prevent slipping. Also, they were fitted on 4WD models as the engine is too torquey for FWD...
    Feb 2007
    1,257
    I take it you know the engine then .
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    I was going to say that the 2 engines are very different so don't, but Mr Adamss24 has beaten me to it. I think Audi upgraded the 150 engine to 163 without too much trouble, but when they went to the 180 (well 177 really) they carried out a major redesign. Don't know why they didn't then produce a 195 version or similar based on the 180, maybe the 2.7 and 3 litre engines were well on the way.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Oct 2003
    up north...
    767
    as regards the skc, yes there is a software /hardware package that can read it from the obd port without needing any info from audi, but it costs about 5500euros and i dont know anyone in the uk with a full version.
    it can read/write the dash/immobilzer data as well as the ecu data as well as program new keys without the skc/pin - its a lot cheaper to get a custom remap though!
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    Jul 2007
    London
    3,074
    Yeah, i am a vw specialist and love working on the 2.5 tdi engine. I had an 98 audi a4 2.5tdi quattro on wich i had fitted a 3.0 bottom end mated to AKE cylinder heads, it was pushing about 240Bhp with just a PSI Box and brand new 180Bhp turbocharger. Sold it to a friend and he crashed it in Europe...Its mainly cosmetic: lights, radiators, front bumper, bonnet,lock carrier, etc. no chassis dammage. I am thinking to buy it back from him though ! The fastest accelerating diesel i have been into ! Propper fast but, would only average 27Mpg if pushed. It was also fully loaded: sport recaro leather, bose, leccy windows all round, rebuilt box and diffs, oettinger/votex bodykit, rial daytona race alloys, FK headlights with HID's, etc. Now i am driving an c5 a6 v6 tdi fully loaded: memory recaro heated leccy seats, folding mirrors, bose, upgraded Eibach sport suspenssion, but its only FWD and nearly 188Bhp is too much for the front wheels !
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    If you love working on the 2.5TDI engine it sounds like we should have been speaking before i got mine rebuilt - twice. Whereabouts are you?
    2005 Audi TT 1.8T
