Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    Oct 2004
    41
    Its That hesitation Again 1.9 tdi a4
    I have an Audi A4 2001 pd 130, and it has the worst problem you can have with a car! A fault that cannot be found! I have taken it to an audi dealer twice to be told there is no fault! I have taken it to 2 individual diesel specialists who can't find the fault!
    The symptoms:
    1.When under load i.e 2nd/3rd gear using torque to pull away it hesitates... in that the turbo is not present for about 1 second and then spools up (violently if you have planted your right foot)
    2. When you turn the engine off the car shakes. This is as if the timing is out, like the engine cylinders are not stopping in correct time.
    3. It randomly may work perfectly for a whole week without problem, this is what is really annoying, because you enjoy how the car should be, but then when you need it the most it is dangerous to drive.
    4. Large amounts of black smoke pour out of the exhaust when it is playing up. Its as if you put your foot to the floor to make sure you get away on a roundabout and it leaves the car behind a thick black smoke.
    Now from every garage that has seen the car they say: we can't find any faults on diagnostics, no errors at all. I have asked all to road test but the car seems to be working fine for them at that time! I have had them change numerous fuel filters and the maf sensor to no avail. It feels like it must be a fuelling issue, yet i don't know if its electrical or mechanical and what it is?
    This must be a common fault on the PD130 or either I have the rarest fault ever or perhaps my local audi engineers are just useless at real engineering.
    I would really appreciate any help anyone can muster as I have had enough, I have had the car for 3 yrs and it has been great but this fault has been on and off getting worse for the last 2yrs.
    Any help appreciated
    Regards
    Jonathon
    Aug 2004
    Aberdeenshire
    740
    Can't you arrange with a garage that you drop by when it's happening and demonstrate the fault to them?
    In my experience that's the only way as I've had faults with cars before that garages couldn't replicate but when I demonstrated it they accepted it and got it fixed.
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    These symptoms proved to be the N75 boost control valve on mine
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Oct 2004
    41
    Thanks fjtwelve,
    Did yours do the same thing then? Mine is acting really bad and stalls first thing in the morning. Who does the work on yours in falmouth? Would like to find a good garage thats not Carrs and knows a bit about engineering instead of laptops.
    regards
    Jonathon
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    This happened not long after i bought the car. I took it back (all the way from my previous home in Scotland to Essex, i was very pissed off) and the tame mechanic at the dealer (Audi Diesels) took one look wandered off to another car in the yard swapped the N75 and bobs your uncle. Took him less than 2 hours start to finish. In Falmouth I use the Skoda dealer in Penryn (confusingly called Falmouth Garage). Are you nearby? They are not particularly fantastic, but much more approachable than Audi in Truro, will discuss a tech problem if you know what you are talking about, and about 2/3 the price. No problems so far after a year of looking after both our cars. The only other remotely local garage i have found is the VW and Audi Centre in 47 Pennsylvania Road, Exeter, tel 01392 422 722.
    2005 Audi TT 1.8T
    Dec 2008
    help
    hi have you any diagnostic codes stored,or can you post them,i repair alot of diesels tdi+pd tdi,vagcom codes are fine....tim cooper
    Oct 2004
    41
    Thanks guys for input,
    I think I'll order a new n75 and give that a go, as for fault codes the audi garage have said there are none. I don't have VAG.com so wouldn't know.
    I'm based in Truro and do know of falmouth garage.
    cheers
    J
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Good grief a fellow poster from within a 100 miles.
    2005 Audi TT 1.8T
    May 2012
    Thank God! Someone who had the same problem that I currently have! Can you help?
    Hi,
    Thanks so much for posting this so long ago! I have exactly the same symptoms that you describe, with my car faulting only when it rains. Having had the MAF, EGR, thermostats, crank shaft seals replaced (a long list of supposed fix-its all of which failed to address the problem), and for months my garage telling me that I was imagining things as diagnostics could find no fault) I would be incredibly grateful if you could let me know if the N75 valve was the problem with your car. If it wasn't did you ever get it fixed in the end. After over two years of this problem gradually getting worse to the point where it is dangerous to drive when it faults, I am desperate for any help Your comment about smothering the car behind in black smoke made me laugh as this is exactly what I do LOL.
    Here is hoping (praying) that you are still on active on this site
    Many thanks, Pascale
    Quote Originally Posted by JSWD32 View Post
    The symptoms:
    Regards
    Jonathon
    Aug 2013
    I am experiencing the same problem, it started 6 months ago and I thought I was mad, I replaced the battery and it has been ok till now, when it got rained on, again no ecu light, and very intermittent, where is the n75, I want to check it for moisture, or replace any ideas? Cheers
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    250
    Made on the red side of Manchester
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    250
    Sorry I forgot to say it's the red dot at the back of the engine bay.
