JMB RetrofitsSky Insurance
    Wheeler97's Avatar
    Mar 2008
    10
    1.9 tdi starts rough after cold nights
    It starts but not like it should.
    Glow plugs OK.
    Battery OK.
    Fuel filter changed recently.
    807
    Mine always sounds rough until its warmed up and then it sounds like a beautiful diesel sound.
    Every derv ive driven has been the same i think.
    Wheeler97's Avatar
    Mar 2008
    10
    It STARTS rough (all diesels run rough after start in winter), but mine STARTS rough.
    807
    I see i dont understand what that means... this forum doesnt get much coverage, possibly get more if you post in the A3 or A4 section
    Vag-com not bringing up anything?
    Wheeler97's Avatar
    Mar 2008
    10
    I think first I will try to adjust ignition timing, if that doesn't work I will connect to VAG COM (it will probably be a sensor then).It's so annoying, I also have a power loss, my a3 isn't a pocket-rocket when engine is fine and now it drives almost as SDI. I guess that whats happens when you have an old diesel problems problems problems
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by Wheeler97 View Post
    Glow plugs OK.
    Battery OK.
    234K on the clock, anywhere below 2oC. Sounds like Lemmy from Motorhead gargling with a bag o bolts!! Give it five minutes and it just sounds like a bag o bolts.... Ah the glorious derv.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
