JMB RetrofitsEM Tuning
Thread: AUDI a3 HELP
    Nov 2008
    AUDI a3 HELP
    hi ive got a3 on a v plate 1.9tdi. had a missing problem. but i found it cut out one and each i time started the car it got more difficult and i could only start it when an epc light comes on then it will stop missing. ive had the fuel pump, injectors checked all ok. n e suggestions. i have feeling i need ecu clocks pod key and barrel.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Check it with VAG COM
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Nov 2008
    whats that mate, im new to the forum. ive already put it on a snap on's machine (modis) and a Bosch machine. Came up with nothing and i cant get mahcine on whilst the light is on cause it goes straight off. thanks
