Turkster
W.Bro.Paul 2.0d Q5 Quattro
Update on my V6
Audi have rebuilt the car with new cams x4 and lifters, and its still running rough, there is engine shake, So they have stripped it all back down again and re done it, they could not see any fauilt on the strip down of the re build, so they have started to re build it all again, new water pump thermostate cam belt and other belts all changed,
So i have a good old chat with the Tech guys, i handed them another fuel pump i had tucked away (without the service manager seeing) as it was all stripped back to the point that to do the fuel pump then now was the time, 4 bolt only, and job done, (keep that to yourself Calvin)
So as i sat here typing i hope the guys have almost rebuilt most of the car, ready for a test run tomorrow afternoon'ish,
The tech guys did show signs of concern of the flywheel, wht the flywheel, well the V6 is know for leaking the oil out of that area of box causing the flywheel to get too get damaged and warp, they did have a peep at it but failed to see any leaks or signs of leaks, but if that is causing the engine to shake then its gear box off and new clutch plat and flywheel thing, £700 for the part, ouch!
The egr valve issue is still there, plug it in and there car is flat as ****, unplug it and off you go!
Im off to cry in my cup of tea
