Badger5AH Fabrications
    Dec 2006
    glow plugs light flashing
    Hi, I've a 2003 A3 8l TDi 130. On the way home the glow plug lamp started flashing, the handbook states that I need to take it to a dealer to get the fault codes read. Anybody else had this fault/know waht it could be? The car is running fine, no loss of power or anything
    cheers
    Aug 2004
    Aberdeenshire
    740
    Might be the brake lights. IIRC, glow plug light is used to indicate a number of problems and brake lights/switch is one of them.
    HTH
    Dec 2006
    thanks Macduff, cleared the fault ok, but will be buying a new brake switch anyway
    Feb 2007
    40
    why??? what is the switch??? read in forum its about £7 ???
    May 2006
    Manchester, England
    30
    Smile
    I have had a intemittent fault on my 2004 TDI sport, Glow light flashing then going out, then for the last 5months its been flashing constant, so i changed the brake switch, it cost me 8 from my main dealer, SHAZAM light out 0 problems!!!! Thanks
