EM TuningAH Fabrications
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    Tandam pump enquiry!
    Golf 115 tdi pd .2001 Y-REG Gt tdi
    Any way i can check the tandam pump timing,manually or with vag/com?
    sluggish car,tried changed,and done nearly everything with this sluggish car! this is the only thing someone has said to check,please help,car drives as if its a 80 bhp !!!
    PD PD PD
    Aug 2004
    Aberdeenshire
    740
    Is there timing on that pump?
    I thought the PDs effectively ran a pressurised fuel rail that the PD injectors took their feed from. The timing is all handled by the PD injector cams and solenoid activation.
