Sky InsuranceVolks Autos
    dan.obi's Avatar
    May 2007
    BIRMINGHAM
    116
    TDi POWER PROBLEM
    hi i have an a3 1997 which run perfectly except for one thing when you put your in 5th gear at about 80ish you get to about 3-4 thousands revs the car dies like the turbo isn't kicking in or something is stoping it from kicking in has this happened to anyone or does anyone know what the problem is, i thought it was the turbo or a split pipe but no, can't get my head around it,
    If anyone knows whats wrong you views and help would be appreciated....
    Milton Keynes UK
    248
    MAF issue?
    Mine was dead after 3000 revs, replaced MAF and all OK.
    You could try cleaning the MAF, although I doubt it will make any difference. Previous posts explain how to do this.
    Check the connector to the MAF as well, the contacts might need a clean.
    dan.obi's Avatar
    May 2007
    BIRMINGHAM
    116
    Quote Originally Posted by moschino
    MAF issue?
    Sorry mate BUT what is a MAF and were is it located so i can give it a look,
    347
    347's Avatar
    Sep 2006
    253
    maf = Mass Airflow Meter
    it is located directly after the air filter housing . it fixes onto the filter hosing and has an electrical plug coming out from the side and a large diameter flexible pipe the opposite end .
    basicly the ecu monitors the amount of air flowing in using the maf , and the ecu then adjusts the fuel accordingly
