Volks AutosEM Tuning
Results 1 to 7 of 7
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    GLOW PLUGS TDI -PD/INTAKE MANIFOLD SENSOR
    IF GLOWPLUGS ARE STAYING ON,WOULD: 1. CAR USE MORE FUEL?
    2. WHAT WOULD CAUSE THIS?
    ALSO IF INTAKE MANIFOLD PRESSURE SENSOR IS FAULTY,WHAT WOULD THIS CAUSE?
    A4 1.9 TDI -PD 2001 (B6)
    Jul 2006
    97
    If the plugs stay on it would not use any more fuel at all, it would wear out the glow plugs. They should only come on for a few seconds,when you put in the key and when you open the door getting into the car.The intake manifold sensor which is on top of the intercooler would make the car a bit slower a tiny bit smokey but not obvious and drink diesel.This happened to me a few wks ago the car just goes to a set setting on the ecu as it cant measure the correct pressure ,the bumper will need to come off i think.I got away with just taking out the passenger headlight but mine is 2.5 so what makes tou think this sensor is gone faulty.Have you checked your diesel cooler under the car for leaks.or exhaust for cracks or damage
    2.5 tdi v6 180 bhp quattro sport mystic blue.18 inch rs8 rims with black between the spokes, audi votex kit, twin chrome scorpion pipes, xennons,heated black buffalo leather sport seats,auto dimming mirrors,serious tailored remap ,ferodo ds 2500 pads front and back upgraded tarrox japan sport competition drilled and grooved discs up front , and ferodo 5.1 racing brake fluid, and about 5k of stereo
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    done everything! 26/27 mpg driven steady. new maff,coolant sensor,all pipes checked for splits,no leaks,no fault codes. Car has brilliant performance,just drinks alot of diesel. Did yours drive/run ok? also how did you find out it was your manifold pressure sensor? mine is a 1.9 tdi,sensor located on intake pipe,near bulkhead.
    WHAT WERE YOU GETTING TO THE GALLON?
    Aug 2004
    Aberdeenshire
    740
    Are you sure your car doesn't have a fuel leak?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    CANT SEE ANY,ANYWHERE. NOTHING ON FLOOR OR ENGINE BAY
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    VW754
    as a fellow stokey Ive dne some asking about for you.
    A mate of mine is one of the partner's at a porche tuning place, Ninemeitser in warrington and he recogn's the best bloke around here for VAG diesels is Andy at PSI tuning in chesterton.
    If my mate Mark rates him then I have to presume he's good
    there number is 563703
    tell him you got his number via a mate of Mark Clowes
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    thanks for the info,i know andy...gud lad, he's confused with this one aswell!,thanks,
    see what else you can do,thanks again
    p.s timing checked and its spot on! is it? next is to flash ecu with oe spec ,just in case.
