Chris NottMonster Motorsport
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    FUEL TEMPREATURE SENSOR
    FUEL TEMPREATURE SENSOR,WHAT DOES IT DO?
    WILL IT CAUSE MY 1.9 TDI TO BAD MPG?
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by vw754
    Measures the temperature of the fuel
    If it's not working properly then may as well change it and remove it from the equation.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    i dont know if its working well,nothings coming up when checked via vag-com,just thort someone may know if it gives bad mpg,before i have the car stripped to check timing,its bugging me this is ..car drives mint,pulls like it should,throws very little bit of black smoke when booted,yet im gettin 26 mpg!
