Sky InsuranceBadger5
    Sep 2006
    Northern Ireland
    knocking noise in A4 TDI Engine
    I've got a 98 A4 B5 TDI (AHU 90bhp engine) with 70k on it. Just recently i hear the engine making a bit of knocking noise at idle, this is not consistent and happens immediately after start up, clears up for about a minute and then continues.
    The engine just doesn't sound as smooth. Any thoughts / advice would be appreciated!?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,972
    with engine at idle slacken 1 injector see if it go's quiet,if not retighten and do next injector,and so on.if slackening of of the injectors go's quiet,you have injector knock.
    Mar 2007
    48
    Quote Originally Posted by Paulw
    Hi there Paul.........have you by any chance had a timing belt put on recently or any major work injectors etc.........it does sound as if your timing is out.....and if it is noisey because of a belt change it means that they didn't quite get it right and the cam/timing is out and slapping some what.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    if the belt timing was out then the engine would run rough throughout its rev range, it may be a hydraulic tappet charging up with oil, most likely.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Mar 2007
    48
    Paul actually hasn't said if it does this if it makes a lowder noise at higher rpm's or not.......i remember i had the very same thing happen to me when i used fully synthetic in my 1Z motor....changed it out for some Castrol GTD and it stopped the tapping .
